Home > Maintenance & Mods (L322) > Motorised "buzzing" noise within dash
aph202
United Kingdom 2012 Range Rover Autobiography 4.4 V8 Orkney Grey
Afternoon folks!
Total newb here - bought my first L322 yesterday! Wanted one forever: this is my first Range Rover or even Land Rover. So far loving the Command driving position, the wafting and the torque! I think I am a convert!! Cool
Got a funny noise coming from the dash though, I thought you folks might have an idea. When I first get going, there is a buzzing (motor-like) sound coming from behind the dash, almost behind the glove box/sat nav screen. If I switch the climate control fully off, it goes away and doesn't seem to return when I turn the climate control back on again.
I have done a bit of searching on this site and found some chat about a cabin temperature sensing fan. https://www.fullfatrr.com/forum/topic64215...ng+climate
I know absolutely nothing about this and am not entirely technical. Is this cabin temperature sensing fan a common issue and/or a likely culprit? Given it goes away when I turn off the climate, I wondered if the two are related.
Thanking you in advance,
Adrian.
Post #685630 14th Feb 2024 5:24pm
Proftinkerpot
Northern Ireland 2012 Range Rover Westminster TDV8 Stornoway Grey
It is the series of stepper motors that control where the air is directed to when the fans run. At least I think that's what they do. MY 2012 Westminster is in at the minute having that issue addressed - noisy fan motor and sounds behind the dashboard. Parts are not too expensive but there is a fair bit of work to strip the dash to access the parts.
I will update when I get mine back hopefully tomorrow evening. I will see if I can get pics of the removed parts so you know what you are looking for.
Post #685653 15th Feb 2024 12:17am
wayneg
Australia 2007 Range Rover Vogue SE TDV8 Java Black
Have a read, it might help.. https://www.fullfatrr.com/forum/topic50136.html 2007 TDV8 VSE
2003 TD6 gone.
2002 P38a gone
1999 P38a gone
1997 p38a gone
1993 VSE gone
1992 VSE gone
1966 Series 2a with V8 conversion gone
Post #685660 15th Feb 2024 6:08am
aph202
Thank you kindly! 🙏
Post #685661 15th Feb 2024 9:36am
