![]() | Home > Technical (L322) > L322 4.4TDV8 No start NO Crank |
kevinp Member Since: 28 Sep 2019 Location: Telford Posts: 1293 ![]() ![]() ![]() |
I would expect one MAF sensor to read '0' untill the second turbo is activated. |
RAGE72 Member Since: 21 Jul 2021 Location: Goole Posts: 32 ![]() ![]() ![]() |
Thanks for your reply but would it also be normal for it to show the 1st maf sensor as massively out of range.
As a side note do the techs on here prefer autodata or haynes pro. I normally use haynes pro but im trialling the autodata although as stated above doesnt seem ti have 4.4tdv8 wiring |
Have you downloaded the 2010-2012 workshop manual from the sites wiki.
so im still trying to fugure this out.
gedebo Member Since: 08 Jul 2021 Location: Stockholm Posts: 3 ![]() ![]() |
I haven't sen it in the 2012 manual, but in earlier publications from LR there has always been an explanation text to the electrical drawings. Maybe in one of the earlier publications? But brake pedal, starter button and maybe glowpluggs spring to mind. If you can find them in livedata, it would be the best way. Then you know that the signal goes al the way to the computer...
