Home > Technical (L405) > Slight clonk from drivetrain on downshift - normal ? |
Sandyt Member Since: 07 Nov 2013 Location: Wraysbury Windsor Posts: 2269 |
I have a 322 and when I bought it 10 years ago on 65k it had a similar issue the dealer replaced the fluid and I paid for it but under the understanding that if it didnt they would reimburse me I had to force them to get an engineer down from the factory who drove the car 200 yds and declared new gearbox all paid for under warranty so go back and shout at them till it is fixed if all the others are saying it shouldn't make a noise then it shouldn't
12th May 2022 4:51pm |
jaysta10k Member Since: 24 Aug 2017 Location: Cheshire Posts: 299 |
Hi did you get this sorted if so what was it as Iām experiencing the exact same issue! Range Rover Vogue SE 4.4 SDV8 SVO Stying Pack
12th Feb 2024 8:06pm |
lambo911 Member Since: 13 Jan 2022 Location: St Albans Posts: 92 |
No, I didn't get it sorted. I tried another dealer and the service manager took it home overnight up the M1 to Milton Keynes.
12th Feb 2024 9:23pm |
Somebody else has mentioned defective engine mounts caused similar issues once changed it cured it. Could be worth a look I suppose. I will try the adaptation reset first if I notice no difference then I will contact GAP for software update rather than going to my local useless steeler who I spoke to today. Range Rover Vogue SE 4.4 SDV8 SVO Stying Pack
12th Feb 2024 10:06pm |
Bora20 Member Since: 03 Mar 2021 Location: Kamloops, BC Posts: 238 |
Here are the steps to getting it fixed:
13th Feb 2024 1:46am |
My SCV8 replacement thread: https://www.fullfatrr.com/forum/topic65744.html Dan. šØš¦ 2013 L405 5.0 SCV8 |
13th Feb 2024 1:50am |
