Home > Technical (L405) > Harsh gear shift sdv8 autobox |
jaysta10k Member Since: 24 Aug 2017 Location: Cheshire Posts: 299 |
Hi guys my car is experiencing the same issue hard thud when I put my foot down on downshift I have phoned my local steeler who have said there is no bulletin out for this issue and they have never heard of it before. Have you any more info on this issue also what was the cost for the software update form the steelers.
12th Feb 2024 2:36pm |
kevinp Member Since: 28 Sep 2019 Location: Telford Posts: 1262 |
Don't it make you want to cry when they say' they have never heard of it before'!! |
12th Feb 2024 2:45pm |
Bora20 Member Since: 03 Mar 2021 Location: Kamloops, BC Posts: 238 |
Highly likely engine mounts. Have someone rev the engine while you watch the motor. It may rise several inches, likely from the left side.
12th Feb 2024 2:49pm |
Would loose engine mounts cause this issue as there is no vibration etc and I only experience this hard thud clunk which feels like it coming from under the floor when I put my foot down and then the car obviously drops gears.
12th Feb 2024 2:57pm |
@fenair what was the cost of this software update please and do you still have details of it invoice etc so I can TELL the idiots at my local steelers that this software update exists.
12th Feb 2024 3:04pm |
1000000000% Dan. 🇨🇦 2013 L405 5.0 SCV8 |
12th Feb 2024 3:12pm |
Hi @Bora20 in another post you mentioned you did a software update via GAP IID tool and this cured the issue correct? Range Rover Vogue SE 4.4 SDV8 SVO Stying Pack Audi A4 2.7 TDI S Line Black Edition phantomn black Previous Cars Range Rover Vogue SE Overfinch Styling 22" Elara's full black stealth colour coded Java black Range Rover sport 2.7 TDV6 Alaska white Range Rover sport overfinch 3.6 TDV8 BMW M3 Carbon Black |
12th Feb 2024 8:12pm |
I did the update after a transmission and transfer case fluid change. I thought that cured it. It fixed the TC noises, after a second flush, but the hard shift/clunk was the engine mounts.
13th Feb 2024 1:49am |
