Home > Technical (L322) > Rusty tailgate bolt
Cinderrella
Rusty tailgate bolt
Hi all,
Rear tailgate cable snapped... Bolt is proper rusty! Been trying for ages now to get it off.
Any suggestions on how to best get this off?
Post #685294 10th Feb 2024 8:38pm
appj62
England 2006 Range Rover Vogue SE 4.2 SC V8 Buckingham Blue
Dremel Previous cars:
S-Max 2007-2013 (only diesel I've had, good car but expensive when diesely bits go wrong, so what's the point?)
Galaxy 2001-2007
Mondeo Estate 1997-2001
Sierra Estate 1993-1997
Uno Turbo 1987 -1993
Fiesta 1984 - 1987
Fiat 127 1982 - 1984
Post #685297 10th Feb 2024 9:11pm
PDC
United Kingdom 2010 Range Rover Autobiography 5.0 SC V8 Barolo Black
A big pair of mole grips Thumbs Up 2010 RR Autobiography 5.0 SC
2020 F-Pace SVR 5.0 SC
2018 RRS HSE Dynamic 3.0
2014 Disco XXV
2011 Disco 3.0
2009 RRS HST V8
Post #685307 10th Feb 2024 11:11pm
Cinderrella
Sorted, admitted defeat and took it to a garage.
Cost....
£free
Post #685309 10th Feb 2024 11:16pm
Bennyis01
England 2010 Range Rover Vogue SE TDV8 Zambezi Silver
Wish I did the same
Tried it myself and it snapped off .Tried to drill it it and it just made a mess so I now have a hole which needs welding and tapping to make good again
Post #685322 11th Feb 2024 7:04am
Proftinkerpot
Northern Ireland 2012 Range Rover Westminster TDV8 Stornoway Grey
When I replaced my tailgate cables, I pulled the rubber caps back and sprayed some white grease using the small straw down into the steel cable to try and protect it from water and rust.
Might be worth thinking about.
Post #685362 11th Feb 2024 4:49pm
SeldomSeenKid
Scotland 2008 Range Rover Supercharged 4.2 SC V8 Stornoway Grey
This was one of the first "10 minute" jobs that I tackled and the first bolt snapped flush to the body.
Cut a slot with the dremel and managed to work it free.
The other three bolts came out without fuss.
Quick question to those who have replaced their straps, should they be tight so the collar can not swivel or loose enough so that it can when the cable folds on closing? ---------------------------------
2008 L322 Supercharged
2007 Porsche 987 Boxster S
2021 BMW iX3
Post #685417 12th Feb 2024 8:57am
Shaun_
My understanding is that they should be nipped up just enough to allow them to swivel around the central insert to allow the cable to move freely into the right position when closed. Otherwise the cable is always being stressed when the tailgate is shut.
Nipping them up just right is very tricky, though, and they have a tendency to work loose over time so I check mine at regular intervals. 2012 TDV8 Westminster in the New Forest
Also: Land Rover Series 3 SWB, Mercedes 280SL, Classic Mini race replica, VW Golf SV
Previously: Audi A8, RR TDV8 Vogue, Audi Allroad, VW Golf GTI Edition 30, Audi A4 Avant, A8, A4 Sport, A6, VW Golf Mk5, Bora, Golf GTI Mk3, Jetta Mk3, Passat, Jetta Mk1, Golf Mk1
Post #685433 12th Feb 2024 11:39am
SeldomSeenKid
Thanks for confirming. Thats what I thought. ---------------------------------
2021 BMW iX3
Post #685434 12th Feb 2024 11:41am
bigbo
United Kingdom 2006 Range Rover Supercharged 4.2 SC V8 Buckingham Blue
if you are using genuine cables and bolts the bolts are shouldered so that the cable cannot be nipped tight.
Like others I spray them with lubricant regularly.
David Range Rover 4.2 Supercharged 2006
Ford Focus EcoBoost 1.5 2017
MG TF 2003
Previous Cars of note
Land Rover Discovery 2
Jaguar Mk2 3.8 - Company car
MG Midget 1974 - Concours
Post #685442 12th Feb 2024 1:15pm
