Home > Technical (L322) > Key fob programming
ballast
United Kingdom 2008 Range Rover Vogue SE TDV8 Java Black
Key fob programming
An exhausted topic, I'm sure, but only found threads with no conclusion.
I can programme both key fobs, but when I programme one, the other doesn't work and so it goes on, with only one working at a time.
Doesn't appear to be a timing thing, i.e. doing the reprogramme quickly doesn't help.
Any ideas please?
Thank you!
Post #685365 11th Feb 2024 5:18pm
pcourtney
what year is your L322 ??
might be worth updating this in your profile please !
Post #685370 11th Feb 2024 6:28pm
ballast
With apologies, not sure why it hadn't updated, hopefully it has now.
It's a 2008 TDV8 - it's the three button key fob (same as D3 of the same era).
Thanks in advance.
Post #685382 11th Feb 2024 7:58pm
Weegie
From your post, I believe you are talking about synching not programming. Two different things.
Stand to be corrected.
If so :
You know NOT to put the second or third key into the ignition when doing the sequence.? It sounds as if you are putting each key in turn into the ignition which has the effect of restarting the procedure??
i.e. Put the first key in the ignition and do the synching process, then, without putting the second key in the ignition, do the synching process on it, same for third key.
At end of synching try the keys
Hope that helps.
Apologies if Iā€™ ve got it wrong. Embarassed John
GAP iiD BT
Post #685384 11th Feb 2024 8:06pm
ballast
Ah, OK. Yes, I was putting each key in the ignition.
Makes sense, will try again tomorrow. Many thanks! šŸ˜
Post #685399 11th Feb 2024 9:21pm
ballast
Thanks Weegie - worked first time! Both keys now fully functional.
Much appreciated.
Chris
Post #685415 12th Feb 2024 7:38am
