Home > Off Topic > Mice
Bill
Phoenix said
Having said that, I've made a 'killing' over the years repairing rodent damage on vehicles....
So it’s you creeping around at night putting mice under my cars! Filters are in fact so good that in certain circumstances, when the ambient air is already polluted, a diesel car will tend to extract more particles from the air than it emits. Emissions Analytics worked with........etc etc
He who dies with the most toys wins...
Post #656793 15th Feb 2023 6:51pm
Bill
recordman wrote:
Allegedly, they don't like the smell of peppermint.
I had mice nest in the engine bay of my car, fortunately no damage done. I brushed on a coating of peppermint oil from the baking aisle at Tesco and they haven't been back.
U may be right , a number of products out there .
https://pestkill.org/mice/peppermint-oil/ Filters are in fact so good that in certain circumstances, when the ambient air is already polluted, a diesel car will tend to extract more particles from the air than it emits. Emissions Analytics worked with........etc etc
Post #656794 15th Feb 2023 6:52pm
Phoenix
I don't need to, a nice warm engine bay or a dry spot out of the wind is often enough to cause one nights chaos, Sometimes they get lucky and find acorns etc. under the bonnet or scuttle, sometimes they get really lucky and find the cabin air vents behind the rear lights and let themselves in that way, feasting on all the crumbs etc. inside the car... Rodent's don't like to go around obstacles, they'll chew through them if they can, be it trim, wiring harness, fuel lines etc. etc. They really are relentless little feckers, one even managed to wreck a turbo by nesting in an air filter, then getting drawn into the turbo by a hole it'd chewed in the air filter, it's skull was hard enough and impacted with enough force to damage the vanes. I have no idea where the rest of it went, probably cremated at 2500rpm after being minced by the turbo - or could well be partially blocking an intercooler.
Post #656812 15th Feb 2023 9:00pm
ergobyte
France 2012 Range Rover Vogue 4.4 V8 Java Black
I discovered by "chance" during a check-up by my indie that my L322 2012 TDV8 has a rodent repellent "Ultrasonic" device installed at the bottom of the engine. it looks like a running wire looping under the engine and supposedly repell all rodents...
the thing is most likely responsible for draining my battery...
don't know about rodent repelling efficiency. haven't had any problems with them so far though. Neutral "it needs some intelligence to undestand you may not have enough"
Post #656850 16th Feb 2023 1:45pm
Gremlin500
I recently discovered early signs of chewing some wires, fortunately they had gone specifically for some accessory wires I’d wrapped in self-amalgamating tape. I got one of these from AE for £4.95 and modded it slightly to fit on the relay box already bolted to the inner wing:
These boxes use a sequence of bright flashing lights and ultrasonic screams to deter rodents, apparently they work better than most other things, time will tell. Current draw is 5mA on standby and up to 17mA when “sounding off”. Humans can only hear a feint clicking of the speaker. The enclosure is IP00 so I drenched the innards in ACF-50 to try to prevent corrosion, but at that price you can chuck a new one in every year anyway. The sequence runs for about 15s, then sleeps for about 5mins, so current draw isn’t significant, my fullfat is always plugged in to the CTEK when at home in any case. “If it ain’t broke, don’t fix it” -where’s the fun in that?
Post #685276 10th Feb 2024 5:11pm
Reggie
United Kingdom 2007 Range Rover Vogue SE TDV8 Santorini Black
I was very surprised when this first happened to me - after so many years in the same place, with so many different cars - why now? And why twice?
Even more surprising was the answer (if true...) in that apparently a huge amount of insulation and suchlike in our cars is now made from plant-based stuff, not plastic.
Basically, mouse food!
Whoever thought that was a good idea?!
(Again, if it's true...)
I now surround my cars with two deterrents while parked.
Firstly, naphthalene mothballs (if you can find them) - but just outside the car and under the bonnet.
Some crushed and some whole.
Inside and outside, I have the plug-in electronic pest/rodent repellents.
I can't tell you which is best as I started both at the same time, but no trouble since...fingers crossed
Post #685280 10th Feb 2024 5:39pm
JayGee
At least you haven't got a Fox problem - this happened to a family member who lost brakes which was a very frightening experience
https://foxrepellentexpert.com/stop-foxes-...e%20fluid. 2012 TDV8 Vogue (L322)
Post #685329 11th Feb 2024 9:12am
Reggie
"Another idea is that car manufacturers use some sort or soy or animal fat substance in the rubber coating that protects car wiring and this proves too difficult for foxes to resist"
So there's some truth in the plant-based theory...
Modern cars are made from food!
Genius.
Post #685331 11th Feb 2024 9:35am
appj62
England 2006 Range Rover Vogue SE 4.2 SC V8 Buckingham Blue
Got rid of 5 mice in my attic. Used chocolate as bait. None found for a week now. Sounded like a herd of elephants in the night😃 Previous cars:
S-Max 2007-2013 (only diesel I've had, good car but expensive when diesely bits go wrong, so what's the point?)
Galaxy 2001-2007
Mondeo Estate 1997-2001
Sierra Estate 1993-1997
Uno Turbo 1987 -1993
Fiesta 1984 - 1987
Fiat 127 1982 - 1984
Post #685348 11th Feb 2024 2:02pm
