Home > eBay & Bargain Spots > 255/60/20 Pirelli Scorpion Zero Take Offs
General
United Kingdom 2012 Range Rover Westminster 4.4 V8 Baltic Blue
https://www.ebay.co.uk/itm/156021342753?fi...R6af6v2oYw
I don't know if anyone has tried them on a L322 or 405 to see if they fit but £50 a tyre looks a bargain.
Post #684006 26th Jan 2024 10:27pm
andyholli
United Kingdom 2012 Range Rover Autobiography TDV8 Santorini Black
I have 255 60 R20 Pirelli Scorpion Zeros.
Not fussed on the looks but I like the ride. Spare wheel well won't take the diameter, of course but no problem getting the speedo to read correctly with the GAP tool.
Post #685242 10th Feb 2024 9:25am
Kenus
Finland 2009 Range Rover Vogue TDV8 Santorini Black
Hi
How would you describe the difference of the ride with the 255/60 20 Pirelli tyres, compared to the original tyre size? Is it much more softer than with the original tyre size or... ?
I'm looking for soft, comfortable ride and trying to decide between 275/50-20 and 255/60-20😁
Post #699330 2nd Sep 2024 5:49pm
andyholli
If that's your goal then the 60 profile sounds better suited.
No complaints after 6kms on this set up - I'm not planning to change when renewal comes up. On the occasional 'pushing on' event they do understeer and things get mushy but there are other cars for that sort of thing.
Motorways and local roads rather than B road progress is what we use our 322 for. Scorpion P Zero with "LR" on the sidewall is as important to me as a switch of profile.
Hope this helps, good luck with your research and choice.
Post #699340 2nd Sep 2024 7:08pm
Kenus
Thank you for your comments, thank's to them I will then go for the 255/60-20 Pirelli's😃
Post #699341 2nd Sep 2024 7:17pm
andyholli
Post #699343 2nd Sep 2024 7:45pm
Kenus
Hi again
I bought a set of Pirelli Scorpio 255/60-20, but have not installed them yet. I just wonder, how did the tyres affect the gears? I mean at what speed does it change to the biggest gear? I suppose you have the eight gear gearbox?
I have the six gear gearbox, and I'm a bit afraid of that it does not change to sixth gear before it has exeeded the speed limits😁
Post #700159 15th Sep 2024 6:10pm
