Home > Maintenance & Mods (L322) > supercharger oil change |
philip1972 Member Since: 16 Jun 2017 Location: Marval 87440 Posts: 526 |
Yes indeed-thank you. |
9th Feb 2024 8:07am |
appj62 Member Since: 07 Aug 2013 Location: Cheshire Posts: 424 |
Heat the pipe up in really hot water. This should make it flexible enough to get past the obstruction enabling majority of oil to be extracted. (Don't worry about any traces of water on the pipe). Still have to do plenty of wiggling though. Previous cars:
11th Feb 2024 9:25pm |
DanRRL322sc Member Since: 16 May 2022 Location: Bedfordshire Posts: 55 |
I did try heating it up with a hot air gun to make the pipe more malleable, i cut a 45 degree end on it to make it more pointed, i even slid a thinner diameter tube inside the one supplied in the kit. All to no avail.
12th Feb 2024 11:52am |
lschwarcz Member Since: 18 May 2019 Location: Hillsboro, OR, USA Posts: 273 |
My question is how to remove all of the fluid from the supercharger? There's a hump in the middle and the drain/fill hole is on one side.
13th Feb 2024 7:11pm |
