Home > Maintenance & Mods (L322) > Anyone tried a "Blue Print" brand air filter for t
stuart_2006
Has anyone tried a "BluePrint" brand air filter for their TD6? The new filter is around 5mm longer than my old one, and although it can be made to sit in the bottom part of the housing with a bit of brute force, the top section of the housing won’t fit back in place at the back (yes, I’ve made sure that the ‘spigot’ on the end of the filter is correctly located in the cut-out in the housing). Just wondering if anyone else has had one and had problems? A genuine LR filter is 498mm long and this new one is around 503mm.
Post #613350 21st Nov 2021 7:21pm
Fox889
I've used Blueprint before on various cars [not the RR though as I normally use Bosch] and never had a problem, but when I had my X5 [same engine as the TD6] I always used Wix filters & never had a problem.
I would return said filter to where it came from & try a different make?
Sorry I can't be more helpful. 2012 Orkney Grey Westminster 4.4TDV8 with Ivory interior.........nice!
Alfa Romeo Giulietta
Austin A40 Farina MK2
1975 Morris Marina 1.8TC
1973 Honda CB250 K4
Post #613383 22nd Nov 2021 7:42am
Caesium
United Kingdom 2012 Range Rover Vogue SE 4.4 V8 Santorini Black
Blue print are made in Kent and are decent parts from my previous experience Christian.
Current Cars
2011 Range Rover Vogue SE
2020 BMW M4 Competition
2019 BMW X4
My RR Blog: www.facebook.com/L322Project
or
https://www.fullfatrr.com/forum/topic61540.html
Post #613439 22nd Nov 2021 6:50pm
Superspoons
Found this thread whilst searching Blue Point regarding rear brakes. Blue Point are part of the Ferdinand Bilstein group so I'm not worried about quality or performance.
https://www.blue-print.com/braking Gavin
https://www.youtube.com/@ChallengingClassics
Post #685076 8th Feb 2024 12:34pm
