Home > Technical (L405) > Oil dilution due to dpf and subsequent engine failures
Page 2 of 3 <123>
AndyRoo
Scotland 2012 Range Rover Westminster TDV8 Fuji White
Hi, I've not experienced this on my FF but it did become quite a problem on our Mazda, that used regen on the exhast stroke and it became so much of a problem that the sump would fill up with diesel.
If you watched the fuel instant fuel consumption it would drop from 50+mpg down to 25 for 5 minutes, then jump back up again. Used so much fuel that instead of averaging 54mpg over a 1000 miles I'd be getting about 37 mpg, That's all fast cruising between Swindon & Reading and back on a daily basis.
I used to have to change the oil every 3 months because there was so much fuel in it. It became uneconomical at £150 a time and having to use special oil. In the end I just sold the car.
I've been keeping any eye on this ever since and every oil change sample the oil, I've so far not detected any diesel in the engine oil in the FF, but in the Mazda I'd get at least 1/2 litre adding between changes. Fuji White / Jet 2012 4.4 TDV8 Westminster
Post #685059 8th Feb 2024 10:00am
Mikey
Re: Oil dilution due to dpf and subsequent engine failures
Alex1976 wrote:
Interesting info on the issue of oil dilution and the resultant engine failures in TDV6 and SDV8 engines.
https://rangeroverworld.co.uk/news
The only issue seems to be trying to find 5W40 oil that is C1 grade.
I'd like to see the technical data they used to back this up, before taking it as gospel...
Post #685060 8th Feb 2024 10:05am
AndyRoo
Hi, there seems to be some folks who are thinking fuel in the oil is down to failed DPF regenerations, this is not true, fuel gets into the sump during the exhaust stroke regardless of whether the regen is successful or not as the DPF is downstream of the exhaust port, i.e. the diesel (or most of it) has already passed through the engine before it reaches the DPF.
There is a case to say that if the engine is turned off that any unburnt fuel in the engine does not get blown out the exhaust and therefore trickles down into the sump, but this is also a false flag as the same would apply to normal operation when the engine switched off mid stroke regardless of if a regen were active or not.
The truth is, it happens because of porus rings, i.e. the better the ring sealing the less likely diesel is to get to the sump, worn rings, scored bores or in the occasional instance where the ring gaps actually align during the process will make the problem worse. a coked up engine is actually a good thing in this regard as there is less chance of unburnt fuel reaching the sump. Fuji White / Jet 2012 4.4 TDV8 Westminster
Post #685066 8th Feb 2024 10:39am
Gremlin500
@AndyRoo:
You are not quite correct in what you say, during the regen process the engine is deliberately overfuelled. If the process is interrupted, it will reinitiate again and again until it succeeds. This extra fuel increases the dilution effect. The engine management algorithm takes account of this, and drops the MTS accordingly.
No-one is saying diesel from the exhaust can find its way into the sump, that’s absurd. Thumbs Up
There are a few good reference articles on this subject which make interesting reading. “If it ain’t broke, don’t fix it” -where’s the fun in that?
Post #685086 8th Feb 2024 1:30pm
AndyRoo
Hi, thanks for the explanation, every day is a school day Thumbs Up
Andy Fuji White / Jet 2012 4.4 TDV8 Westminster
Post #685088 8th Feb 2024 1:40pm
Zebedee
United Kingdom 2013 Range Rover Vogue SDV8 Santorini Black
How do the engines test for oil dilution?
I'm assuming there isn't a sensor specifically for measuring the amount of diesel in the oil, or is it as simple as an increase in oil level?
Has anyone tested their oil after 6k or 12k to really know the level of oil dilution? I know Millers Oils do a Oil Sample Analysis for £39.95 - send in 90ml of oil and they will tell you what is in there that shouldn't be. That might be worth having a go. Current:
- 2017 L405 3.0 V6 Autobiography
Sold:
- 2013 L405 4.4 TDV8 Vogue
- 2004 L322 4.4 Vogue (BRC LPG)
- 2002 L322 4.4 HSE (having fixed timing chain guides)
- 2000 P38 4.6 Vogue (BRC LPG)
- 1981 2-door In-Vogue
- 1980 Ex-Army SIII LWB
- 1976 SIII LWB
- 1968 SIIA
Stripped for parts:
- 2003 L322 4.4 Vogue
Post #685106 8th Feb 2024 5:00pm
Gremlin500
Hi Zebedee,
As I said above, it’s algorithm based, the ECU looks at many different parameters and decides how the car has been driven, and calculates the expected dilution, it is not measured directly from one or two sensors.
There are a few articles on this, already posted on this forum, but can I hell find them! Censored “If it ain’t broke, don’t fix it” -where’s the fun in that?
Post #685111 8th Feb 2024 5:50pm
ChrisJC
United Kingdom 2014 Range Rover Vogue SDV8 Aintree Green
I don't understand how you can over-fuel a diesel. They always run excess oxygen, so any excess fuel will just burn and deliver horsepower?!?!
Chris. L405 - 4.4SDV8 Vogue
P38 - 4.6V8 HSE
Land Rover series IIA V8
Post #685116 8th Feb 2024 7:54pm
Gremlin500
Hi ChrisJC,
It’s not strictly overfuelling, it’s called a “post injection”, meaning there is a second injection of fuel microseconds after each normal compression/ignition phase injection, which allows uncombusted fuel into the cylinders, thence the exhaust to the DEF for catalytic combustion to burn off the soot at around 600C-650C.
I will try to find the articles I spoke of, but how to post a document on here?
There are already links to these documents on this forum, but I can’t find them and can’t remember who posted them. “If it ain’t broke, don’t fix it” -where’s the fun in that?
Post #685117 8th Feb 2024 8:04pm
Kot
Gremlin500 wrote:
Hi Zebedee,
From WSM but note this 7% mentioned below, was increased to 10% by JLR for those who had the software update (due to customer complaints regarding increased frequency of service alerts). And I guess already installed for newer cars dated after that bulletin?
Engine oil dilution can occur due to small amounts of fuel entering the engine crankcase during the post-injection phases. This has made it necessary to introduce a calculation based on driving style to reduce oil service intervals if necessary. The driver is alerted to the oil service by a message in the IC.
The DPF software monitors the driving style and the frequency of the active regeneration and duration. Using this information a calculation can be made on the engine oil dilution. When the DPF software calculates the engine oil dilution has reached a predetermined threshold (fuel being 7% of engine oil volume) a service message is displayed in the IC.
Depending on driving style, some vehicles may require an oil service before the designated interval. If a service message is displayed, the vehicle will be required have a full service and the service interval counter will be reset.
 2018 SE SDV8 4.4 Byron Blue
Post #685118 8th Feb 2024 8:05pm
Kot
Gremlin500 wrote:
Hi ChrisJC,
Here
https://www.fullfatrr.com/gallery/albums/u...ration.pdf 2018 SE SDV8 4.4 Byron Blue
Post #685119 8th Feb 2024 8:07pm
ChrisJC
Interesting - thanks!
That also explains why there is a butterfly in the air intake - something else for which there is no need on a Diesel engine.
P38 - 4.6V8 HSE
Post #685120 8th Feb 2024 8:23pm
Gremlin500
Articles on regen and dilution:
For those who are interested, a little light reading:
https://www.dropbox.com/s/d0bcrd7sve4l598/...d.pdf?dl=1
(should be 19 pages!).
Post #685121 8th Feb 2024 8:26pm
Gremlin500
Thanks Kot! Bow down “If it ain’t broke, don’t fix it” -where’s the fun in that?
Post #685122 8th Feb 2024 8:28pm
Kot
My God you must have good eyes Rolling with laughter I can hardly read it Rolling with laughter
You could of course read page 1 where you will find a better copy which is just about more readable if you use magnify Rolling with laughter
https://www.fullfatrr.com/gallery/albums/u...lained.pdf 2018 SE SDV8 4.4 Byron Blue
Post #685125 8th Feb 2024 8:32pm
Page 2 of 3 <123>
