Home > Technical (L322) > Dead in the water L322 TDV8
gm0rdi
Scotland 2011 Range Rover Vogue TDV8 Santorini Black
Greetings!
I'm struggling with my beast which - without provocation - has suddenly decided that it is "Smart Key Not Found" time Sad And, before you ask, I do have two keys with fresh batteries.
The only thing that functions (apart from the instrument cluster, just to the point it displays that message) appears to be the interior lights. Let me be clear - I'm not expecting anyone to miraculously diagnose the cause of this remotely ... although I would be eternally grateful (etc) if someone did!
Currently it is sat in a fairly inaccessible hotel car park, and I've no hope of getting it recovered unless and until I can disable the steering lock. Obviously the EPB and getting it from PARK to NEUTRAL are no issue. But the steering lock ... oh my.
As far as I can tell, I have only the following options:
1. Get it fixed on site
2. Get it recovered to someone who will find and fix the fault
3. Leave it where it is until the planet's eco system recovered is as a pile of rust
Anyone have any ideas about the steering lock? Or perhaps the fault itself?
FWIW ... from the research I have done (and the fact that there is evidence of corrosion on the Park Assit module connectors), my hot favourite is that this is a CANBUS issue. But I have been wrong before.
All contributions welcome, but please be gentle with me ...
Post #684958 7th Feb 2024 1:39pm
Dtech
England 2011 Range Rover Vogue 4.4 V8 Santorini Black
Try removing the battery lead for a minute or so. Nothing to lose, and You never know it may sort it.
Post #684962 7th Feb 2024 1:57pm
Fla
Ireland 2012 Range Rover Westminster 4.4 V8 Zambezi Silver
Could this be a KVM fault? I believe it can happen where the KVM module fails due to age or water ingress. From my research on getting a second key for my l322 the KVM is easily removed and there are people who can fix and diagnose them. That would be an easy access job. The other thing it may be is the antennas for the Keys. From memory there are quite a few in the car, its in the manual. Is it possible this has failed or the electrical circuit for this system has failed? Current yokes
2012 4.4 TDV8 Westminster
2006 Disco 3
Scoobie GT wagon
Mx5 G Ltd
TT S Line
Pajero JDM Exceed
Post #684963 7th Feb 2024 2:06pm
gm0rdi
I'll give it a bash tomorrow; I did pull Fuse 5 (which in theory should do the same job) and that made no difference. But as you say, it's a zero cost thing and worth a go.
Post #684964 7th Feb 2024 2:10pm
gm0rdi
Well absolutely it could be. Trouble is I don't know where to find that.
I have a question about the KVM - is that the thing that the keys are paired with? I'll need to ponder how I can identify that as a possible cause of the issue.
Post #684966 7th Feb 2024 2:22pm
Dutchgit
Germany 2008 Range Rover Vogue TDV8 Stornoway Grey
Just out of possible interest :
What's a KVM do ? Shocked
Post #684978 7th Feb 2024 5:29pm
pcourtney
KVM ( Keyless Vehicle Module )
https://abrites.com/blog/the-ultimate-guid...erspective
Post #684989 7th Feb 2024 7:04pm
Dutchgit
Ah ! Cheers for that!
Post #684993 7th Feb 2024 7:47pm
GraemeS
Have you tried holding the key in the very specific position against the lower panel below the light switch then attempting to start? The owners manual has following instructions and a picture showing the key positioned below the light. The key may need to be moved about a little to get it to work.
Position the Smart Key against the underside of the fascia with the buttons facing downwards.
Post #684996 7th Feb 2024 7:58pm
pcourtney
If that does not work it might be worth giving Oliveston a call in the morning, they might have a way to help you
Telephone 03302 233 446
https://oliveston.com/blog/
Post #685015 7th Feb 2024 9:19pm
gm0rdi
Greetings - I appreciate the input, but that doesn't change anything (with either of the keys I have).
My first Range Rover was 47 years ago - 3 door, plastic seats, twin carb V8. Had one ever since, moving up through the various builds.
If I knew then what I know now, I may well have bought something else ... but if its in the blood, you are clearly doomed ...
Post #685023 7th Feb 2024 9:45pm
pcourtney
If you have "Smart Key Not Found" message, then at the very least you should try placing your key just below the light as per instructions shown above, not sure why you would not want to do that in your quest to troubleshoot the issue - please don't shoot the messenger Smile
Post #685024 7th Feb 2024 10:02pm
Ansi
Switzerland 2010 Range Rover Autobiography 5.0 SC V8 Adriatic Blue
Is there, by any chance a Construction crane with remote control nearby?
I had same problem once in Spain, the remote control interfered with the radio traffic of my key.
After I persuaded the crane operator Bow down to switch off the remote control for 5 minutes, I could start and take off again Whistle
Post #685160 9th Feb 2024 8:43am
gm0rdi
Greetings.
No crane anywhere nearby, and I'm acutely aware of the possibility of interference / blocking of 433.92 MHz by "dirty" (in terms of spectral purity) licence-free low power devices; next time I am at the car I can easily verify that something somewhere isn't doing that - I have a weapons-grade spectrum analyser as part of my standard armament.
My next move is going to be a scope on the various BUS lines to see what I can see.
Thanks for the input!
Post #685166 9th Feb 2024 9:50am
drphilgarner
United Kingdom 2011 Range Rover Vogue 4.4 V8 Buckingham Blue
Let us know how you get on, this is an interesting one! 2011 4.4 TDV8 Vogue
Post #685515 13th Feb 2024 9:09am
