![]() | Home > Technical (L405) > Oil dilution due to dpf and subsequent engine failures |
Alex1976 Member Since: 22 Mar 2023 Location: Bucks Posts: 146 ![]() ![]() ![]() |
Interesting info on the issue of oil dilution and the resultant engine failures in TDV6 and SDV8 engines.
ChrisJC Member Since: 14 Sep 2023 Location: Northants Posts: 132 ![]() ![]() ![]() |
They don't give the driving style used to get those results.
Richie N Member Since: 29 Dec 2023 Location: Kent Posts: 358 ![]() ![]() ![]() |
Interesting but I can’t find any 5w40 c1 oil 🤷♂️ |
Kot Member Since: 10 Mar 2021 Location: broadland Posts: 1261 ![]() ![]() |
I change mine every 4k miles anyway due to my driving style and I watch the app starting to count down to plan ahead for oil and filter changes.
Gremlin500 Member Since: 11 Mar 2022 Location: Newcastle, UK Posts: 1587 ![]() ![]() ![]() |
Also, you really need to change the oil pump minimum every 6-7 years, -with the TDV6 engine, this coincides with the timing belt changes. An oil pump failure can lead to a f |
goldeneye32 Member Since: 10 Jan 2024 Location: Hampshire Posts: 44 ![]() ![]() ![]() |
The last two cars I've owned (both Mercs) were traded with over 270k miles on each of them, but before i bought them I looked in the trader for high mileage models, mainly because I was doing 35k miles/year and if I saw them with 400k miles on them, then I knew that it would be possible for them to do that mileage.
I am carrying out an oil and filter change every 6 months which equates to circa 6,000 miles. My oil service reminder has just popped up right on schedule (6,000 miles since last service).
Vogue Member Since: 31 Jan 2008 Location: on the hill Posts: 3757 ![]() ![]() |
This is what’s listed on the LR iGuide App:-
Sorry, I probably wasn’t very clear. I can find the specified Castrol to LR spec no problem and this is what I have used so far. It seems the 5W40 is very difficult if not impossible to find in C1 classification but is available in C3.
What’s the recommended 5w40 then? Thanks.
Engine bang sir ?
GraemeS Member Since: 06 Mar 2015 Location: Wagga area Posts: 2561 ![]() ![]() ![]() |
C4 supersedes C1, not C2 or C3. |
ACEA dropped the C1 category from the 2022 edition of their oil sequences. C1 oil is primarily for Land Rover applications. I’m sure the oil companies will continue to manufacture C1 oils for the foreseeable future.
