Home > Off Topic > Avin a Giraffe! |
Rant:
10th Aug 2009 2:56pm |
Larry Member Since: 03 Dec 2008 Location: East Midlands Posts: 262 |
As Ivan says, a RR with a trailer seems to do all the above (in bold) without extra the running costs, maintenance or hassle. Also easier to store. If you only need it occasionally, I'd even consider hiring a trailer when you need it rather than storing it etc. At least you always get the right type of trailer for the job in hand. Why not go for a tatty old Disco instead of the Espace? Similar load space (may have higher payload capacity) all the mod cons and you can take it offroading without having to worry about the paintwork on the Rangie |
10th Aug 2009 4:22pm |
Espace Vs Disco:
10th Aug 2009 5:09pm |
nbunney Member Since: 10 Aug 2008 Location: Lancashire Posts: 2040 |
Dan
10th Aug 2009 8:08pm |
There are stacks out there sub £500 but none on the door step, this was on the way to work so would have been handy. I dont mind getting one from further away, but is a pita if its a heap etc.
10th Aug 2009 8:10pm |
