![]() | Home > Technical (L405) > Multiple cylinder misfires (4 & 5) post 2-month service |
j3blaha Member Since: 04 Feb 2024 Location: Wake Forest, NC Posts: 5 ![]() ![]() ![]() |
Following a brief test drive yesterday, I experienced no engine light or stumbling issues. As mentioned before, this issue is intermittent and the car has been driven hundreds of miles without issue. One thing I've been thinking about is the catalytic converters. The original engine was lost at 87K miles following a breakdown of the cooling system. Is it possible the driver's side catalytic converter was damaged during the time of the engine failure? Could a bad catalytic converter cause random misfires on the same bank?
dingg1 Member Since: 29 Jun 2013 Location: PORTUGAL Posts: 1348 ![]() ![]() |
Cylinders 4 and 5 are on opposite banks |
It has been my understanding that cylinders 4, 5, & 6 are on the left side.
My apologies for some reason I assumed it was a 5.0 sc |
Good AM. Yesterday, I conducted a back pressure test on the upstream 02 sensor port on bank 2. This confirmed there are no issues with the bank 2 catalytic converter. Since I removed this sensor, I am going to replace with a new one.
Could this be a fuel delivery issue? The issue starts when the engine gets warm and is idle or at a low speed. Never an issue on the highway and the issue can be resolved by a restart. Is there a component of the fuel delivery system that is impacted by heat and/or lower RPMs? Not sure if there is a dirty fuel filter, faulty fuel pump, or fuel pressure sensor. |
