Home > Technical (L322) > 3.6 TDV8 mk3 (2010) restricted performance. Advice Needed |
V8 Bob Member Since: 15 Mar 2018 Location: Cumbria Posts: 370 |
Check voltage with engine running should be circa 14 volts this should indicate if alternator is issue ie not charging the battery. 2012 tdv8 Westminster arrived Jan 19 gone Dec 23
31st Dec 2023 12:14pm |
Blinche Member Since: 29 Dec 2023 Location: Caen Posts: 9 |
Actually based on the gap IIDtool it is around 14v
31st Dec 2023 12:21pm |
jimmie Member Since: 19 Jul 2014 Location: Warsaw Posts: 163 |
check pending errors |
31st Dec 2023 6:24pm |
Jimmie
31st Dec 2023 6:40pm |
Weegie Member Since: 09 Jun 2014 Location: East Sussex Posts: 3241 |
When you checked the voltage was that with the cruise control switched on? John
31st Dec 2023 6:57pm |
default setting in iid is to show only stored errors. You can select lot more. If you turn on to show pending errors, then you get lot of not active, but occured just once. It can show you additional symptoms. |
2nd Jan 2024 9:41pm |
Ah ok i didn’t know
3rd Jan 2024 6:32am |
Hello
6th Jan 2024 11:36am |
yes. Can it be. |
6th Jan 2024 1:28pm |
Ok
6th Jan 2024 2:20pm |
Hi all
18th Jan 2024 8:47pm |
Alléluia
2nd Feb 2024 7:41pm |
Apps Member Since: 24 Dec 2024 Location: Leeds Posts: 21 |
What sensors did you end up changing as I'm having the same issues |
2nd Jan 2025 2:54pm |
Hello
2nd Jan 2025 3:11pm |
