Home > Technical (L322) > 4.2 SC gearbox oil cooler pipe replacement
JackPeters125
United Kingdom 2005 Range Rover Vogue SE 4.2 SC V8 Java Black
Whilst my RR has been in the garage for a new water pump they have found it’s leaking oil from a corroded gearbox cooler pipe.
Has anyone replaced these? Just wondering how big a job this is and if it’s something I could do on the drive?
Post #682799 15th Jan 2024 5:15pm
JackPeters125
Just an update on this. My mechanic and myself are struggling to find any pipes in the uk.
I believe the part numbers are: UBP500300 & UBP500380 (two separate pipes)
Does anyone know whether the RR Sport or any jag models use the same pipes?
Will be for a 55 plate 4.2 SC.
Any help or direction would be greatly appreciated!
Post #684554 1st Feb 2024 5:26pm
dhallworth
Give Robin at Duckworth Land Rover Parts Department a call. He’ll be able to help you source it and if there are none available he’ll be able to check cross references. 2002 4.6 Vogue SE - Alveston Red with Lightstone Leather
2007 Range Rover Supercharged in Java Black with Ivory Leather
Post #684568 1st Feb 2024 7:57pm
JackPeters125
Ah thanks. Will give them a call tomorrow
Post #684573 1st Feb 2024 9:00pm
