Home > Maintenance & Mods (L322) > what mileage do suspension components die |
Danb_220_2019 Member Since: 02 Jan 2023 Location: Suffolk Posts: 262 |
My 2012 4.4TDV8 had 79K on when I bought it. I have since replaced all four front arms, lower ball joints, ARB droplinks all round, both front struts and one height sensor which had failed.
1st Feb 2024 11:52am |
deficit Member Since: 11 Jan 2024 Location: bristol Posts: 6 |
Do you remember which height sensor it was? Are there 2 per car or 4 per car? |
1st Feb 2024 12:16pm |
There are four, one on each corner.
1st Feb 2024 12:40pm |
sounds like no rhyme or reason to which height sensor goes first then :-/
1st Feb 2024 12:44pm |
There's no reason to assume the height sensors even need replacing. They're pretty reliable items with not a lot to go wrong. 2012 (L322) 4.4TDV8 Vogue SE, RSE, Fuji White over Arabica.
1st Feb 2024 12:48pm |
JayGee Member Since: 27 Jul 2021 Location: London Posts: 3283 |
Life of suspension componenets not realy related to mileage as a high miler driven sensibly mosly on A roads and M-Ways will not have stressed the componenets as much as a low miler driven agressivley in urban enviromnerts over curbs and speed humps. These cars drive quite well as they age so only replace when a component fails as you can spend a not inconciderable forture preemptivley replacing bits that may never fail. 2012 TDV8 Vogue (L322) |
1st Feb 2024 1:08pm |
Snowy90 L322 Member Since: 24 Aug 2015 Location: Surrey Posts: 220 |
My experience is that front air shocks probably go about 60,000 - 80,000 miles having done over 100,000 in mine now on 166k i have replaced both fronts. One went quite soon at 60,000 and the other about 80,000. So possible due a failed one? Rears are still original.
1st Feb 2024 1:54pm |
Merchy Member Since: 14 Feb 2021 Location: North Wales Posts: 1210 |
At the moment I would just replace the other front airbag, but inspect it first, just in case it is not the original and has already been changed at some time.
1st Feb 2024 6:31pm |
yep, that's pretty much where I'm at with it. I didnt give the full list of things i'm having done as this post was just about suspension but...
1st Feb 2024 6:42pm |
fanders Member Since: 10 Jul 2013 Location: Hants, UK Posts: 318 |
I’ve just replaced both front airbag/struts at 103,000 miles due to one developing a leak. They were the original ones looking at their date of manufacture. I have two rear Bilstein airbags for the rear which will be going on shortly, as preventative maintenance.
1st Feb 2024 7:03pm |
