Home > Technical (L405) > Multiple issues but no fault codes with Gap ID tool! |
Gremlin500 Member Since: 11 Mar 2022 Location: Newcastle, UK Posts: 1222 |
………. “If it ain’t broke, don’t fix it” -where’s the fun in that? |
28th Jan 2024 10:37am |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 34957 |
start with the battery.. ... - .- -.
28th Jan 2024 10:59am |
Doublejjd Member Since: 03 Jun 2022 Location: Dripping Springs, TX Posts: 6 |
thanks. tailgate works fine. i'll try disconnecting the battery. will keep you posted thanks for the input. |
28th Jan 2024 7:35pm |
Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16187 |
Has damp got in somewhere? I see your in Texas but it does rain there right |
28th Jan 2024 7:41pm |
tried disconnecting the battery. While we have had rain, it was in the parking garage at the airport all week while it rained and it was sunny dry when it just stopped working. Think I may try to find a used door latch/actuator and replace it. will keep everyone posted. thanks! |
30th Jan 2024 2:07am |
Well replaced the door latch hoping that would solve it but it didn't. I'm just stumped as to why the Gap diagnostics tool isn't seeing any code.
3rd Feb 2024 7:33pm |
CS Member Since: 14 Apr 2015 Location: Edinburgh Posts: 1348 |
See "ghosts in the machine" thread below, maybe problem with earth point in wheel arch, which seems to cause multiple electrical faults? Only Range Rovers since 1988 |
3rd Feb 2024 10:34pm |
comports Member Since: 20 Dec 2010 Location: Colchester Posts: 1663 |
I'd check the charge state of the battery - you mention that it has been sat for a week in an airport carpark all week - the alarm may have been going off or some other drain on the battery.
4th Feb 2024 8:56am |
Tinman Member Since: 22 Mar 2017 Location: kent Posts: 1140 |
Check the ground connections under the front wheel liners. 2017 SDV8 4.4 silicon silver AB
4th Feb 2024 9:03am |
Well finally got everything sorted. The ground under the front driver's seat broke. They had to disassemble most of the interior because the driver seat didn't move. Appearently multiple control units used that ground. It took so long because their one mechanic who could do aluminum welding was out for an extended time. Not a big deal ultimately. They did a ton of trouble shooting and to trace it back to that was impressive. Most places would have given up or replaced a bunch I f components.
5th Apr 2024 1:41am |
