![]() | Home > Maintenance & Mods (L322) > 2011 tdv8 4.4 rocker cover removal -hard job? |
Dtech Member Since: 29 Nov 2014 Location: Yorkshire Dales Posts: 70 ![]() ![]() ![]() |
My son who is a mechanic recently replaced my n/s cover, which had the same problem as yours. Yes you have to remove the injectors, but the rear one won’t clear the bulkhead and come out without loosening the engine mount, and lifting the engine slightly. |
johnboyairey Member Since: 11 Jan 2013 Location: surrey Posts: 2035 ![]() ![]() ![]() |
ok, did he need any special tools to get the injectors out? |
jimmie Member Since: 19 Jul 2014 Location: Warsaw Posts: 166 ![]() ![]() ![]() |
big bag of Xanax. |
looks like this explains the injectors and the rear clearance. |
No. The injectors are quite straightforward, held down with two short bolts on each. They pulled out easily by hand, with no special tools needed. As mentioned previously the back one won’t clear the bulkhead, without lifting the engine slightly. |
