![]() | Home > Maintenance & Mods (L405) > Upgrade the Instrument Cluster on a 2016? |
Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16334 ![]() ![]() ![]() |
I actually think it maybe a yes?
zenman63 Member Since: 14 Nov 2021 Location: Warwickshire Posts: 164 ![]() ![]() ![]() |
They are making digital dash for them but not sure what there like.
DrF Member Since: 30 Jun 2014 Location: South East Posts: 1464 ![]() ![]() ![]() |
Evening JDGeorgia,
JDGeorgia Member Since: 11 Oct 2023 Location: Atlanta GA Posts: 159 ![]() ![]() ![]() |
Good to see the Good Dr! L494 Lever is holding up like a champ. I've driven it enough now that it is barely a novelty! ![]() I am on just under 104K miles - so it will go to the Indy in another thousand miles or so for a 710 change and possibly a fuel filter change. It will be interesting to see what the Tech's say. So far only the Service Writer has seen it. As far as the Instrument cluster... Mine has the 2 dials and there is a bit of information that you can display, but you don't get to choose between the Navigation/Radio/Offroad Info/etc...
There has to be some sort of computer either in the cluster itself or some kind of 'module' that controls it. I was hoping Ol' Phoenix would jump on and say... you would have to create a pigtail and enable the module through GAP IID... but I may have answered my own question. I took a peek at the link you attached and as far as the skin... I kind of think those are some sort of a 'picture' that they can upload so your Speedo has a cool ring outline and the pic of the truck in the middle is sleeker... I don't see the categories at the top where you could get to 'Display'... I think there is a module somewhere... Good to 'see' you. I hope your Holidays were outstanding and your Mamma 'n them are well. 2006 L322 HSE LUX 4.4NA Jag V8 Buckingham Blue/Ivory - 'Col Reb' Rolled Yahtzee Aug 2023 222,222Miles 2016 L405 HSE TD6. Santorini Black over Almond. - 'Donna the Diesel' Only L405 IN THE KNOWN UNIVERSE with an L494 Shift Lever Fitted! 97K at purchase Sept of 2023 |
That does look closer to the facelift Cluster - at least in terms of the Speedo/fuel gauge on the left and the Tach/temp on the right... I will take a look. Thanks for posting that! 2006 L322 HSE LUX 4.4NA Jag V8 Buckingham Blue/Ivory - 'Col Reb' Rolled Yahtzee Aug 2023 222,222Miles 2016 L405 HSE TD6. Santorini Black over Almond. - 'Donna the Diesel' Only L405 IN THE KNOWN UNIVERSE with an L494 Shift Lever Fitted! 97K at purchase Sept of 2023 |
whooooo doggie!
will308f Member Since: 19 Apr 2022 Location: plymouth Posts: 499 ![]() ![]() ![]() |
just been watching a video (https://youtu.be/algWb35qIIs?si=Wb0rsLykZP7I-qm_) and that range rover has had the instrument cluster replaced for the newer one |
He says it is upgraded... but the quick glance at it - it looks pretty much the same as mine...
Evening JDGeorgia,
Always a pleasure to hear from The Good Dr!
