Home > Maintenance & Mods (L322) > Beware Mahle Oil Filter Seals
AndyRoo
Scotland 2012 Range Rover Westminster TDV8 Fuji White
Hi, managed to trace my top end oil leak turns out it was actually from the oil filter housing with oil getting past the filter oil seal.
See pictures below, left seal is the one I took out, only been in the car 4 weeks, the right seal the one just out of the box.
I never noticed the seal "ovaling" before, but I'll be checking back regularly. Never had this happen in years of usinf Mann filters.
Anyone seen this before, is the Mahle brand tainted ?
Andy
 Fuji White / Jet 2012 4.4 TDV8 Westminster
Post #683415 21st Jan 2024 12:34pm
garyRR
Has it been over-tightened or torqued when hot? 2015 Range Rover Autobiography 4.4 SDV8
Post #683429 21st Jan 2024 1:31pm
AndyRoo
Hi, Not that I know of, same as always. Torque is mentioned on the cover, can't recall off the top of my head, 25nM if I seem to remember, something like that.
Used a small torque wrench so wouldn't overtighten it, engine would have been warm to change the oil but not hot to scold nor cold.
At first I thought the casing may be cracked causing the leak but I decided I'd change the seal anyway as a precaution, that's when I noticed the ovaling.
Rubber is still very soft, so it's not hardened, it's just mis-shapen.
I think the filters came from Britpart, I'll go back to Mann & Crossland, never had this problem before and I don't want to risk it so when the new ones arrive this is going in the bin.
Andy Fuji White / Jet 2012 4.4 TDV8 Westminster
Post #683435 21st Jan 2024 4:31pm
garyRR
Was it a Britpart filter and seal or a Mahle filter and seal? Mahle are the OEM supplier for many brands, so unless it's been done up too tightly, I can't see their parts failing. Britpart/Borg & Beck and similar, I have found to be of inferior quality. 2015 Range Rover Autobiography 4.4 SDV8
Post #683454 21st Jan 2024 6:43pm
Dtech
England 2011 Range Rover Vogue 4.4 V8 Santorini Black
Was the o ring sufficiently lubricated when fitted? If fitted dry it would cause distortion/damage when tightened.
Post #683457 21st Jan 2024 6:55pm
AndyRoo
Hi, I bought them from John Craddock Ltd, was supposed to be a Britpart part but what actually arrived was Mahle, see below. It's the right part, just dubious quality.
Post #683459 21st Jan 2024 6:57pm
GraemeS
I've fitted several Mahle to mine without any leaking.
Post #683461 21st Jan 2024 7:41pm
AndyRoo
Could just be a one off I guess Fuji White / Jet 2012 4.4 TDV8 Westminster
Post #683462 21st Jan 2024 7:43pm
Mikey
Mahle are OE for the 2.7, Mann are OE for 3.0, and that's how we use them
Never had an issue with either. Don't use Crossland though, that's just asking for trouble Shocked
Post #683463 21st Jan 2024 7:44pm
knwatkins
Mahle are top quality filters and OEM for many major automotive manufacturers.
Very odd. Kev
2014 L405 RR Vogue SE 4.4 SDV8 in Corris Grey
2010 L320 RRS HSE 3.0 TDV6 in Stornoway Grey
Post #683476 21st Jan 2024 8:47pm
Danb_220_2019
United Kingdom 2012 Range Rover Vogue SE TDV8 Fuji White
I've used nothing but Mahle filters for years in the cartridge type filters on various cars I've owned, and never had any leaks from any of them except when I forgot to change the O-ring one time. 2012 (L322) 4.4TDV8 Vogue SE, RSE, Fuji White over Arabica.
Previous V8s: BMW 645Ci, P38 4.6, P38 4.0, Merc CL500
Previous others: Honda x1, Volvo x7, Rover x6, BMW x6, Ford x1, Mercedes x2, Skoda x3, VW x2, Renault x2, Citroen x1, Mazda x3, Nissan x1, Audi x3, Kia x1, Fiat x4, Subaru x3, Austin x2, Triumph x2, Jeep x2, Hyundai x2, Lexus x1, Mitsubishi x1, Saab x2... and some others I've forgotten!
Post #683515 22nd Jan 2024 10:30am
JayGee
Andy
Take this up with the supplier. I'd never put a 'S**tpart' product in anything vital but they are OK for peripheral stuff. They are cheap for a reason. 2012 TDV8 Vogue (L322)
Post #683517 22nd Jan 2024 10:58am
p38arover
Australia
Hmm, I changed mine today before I saw this thread. I didn’t lube the O-ring. I’ll loosen it tomorrow and do that. Hopefully not too late.
I used a Mann+Hummel filter.
As an aside, they come with a small rubber seal. What is that for? Ron B. VK2OTC
2003 L322 V8 Auto
2007 Yamaha XJR1300
Post #683524 22nd Jan 2024 12:36pm
AndyRoo
I think it's for other car adaptations that use the same filter element. My BMW did and the small seals were from a prong attachment that went deeper inside the engine.
I couldn't see anywhere they might be used in the RR.
Post #683525 22nd Jan 2024 12:46pm
p38arover
Australia
Thanks Andy.
I notice that RAVE shows a sealing ring at the bottom of the centre "spigot" and states "11. Lubricate new 'O' ring and sealing ring with engine oil and fit to cap and centre spindle.".
However, that ring looks to be at the top of the spigot and the sealing ring that came with the oil filter is a smallish (about 1/2") hard plastic washer. I'd expect that seal at the top to be an O-ring.
Today I pulled the new filter out and oiled the O-ring. I didn't try removing the centre spigot to see if there was sealing ring at the bottom. Maybe next time.
When undoing the cap, it was tight. After oiling the O-ring, the cap screwed in relatively easily. I used my tension wrench to tighten it to 25Nm - that figure is embossed on the cap BTW. Luckily I had a 36mm socket in my 3/4" drive socket set and a 1/2"-3/4" adapter for my tension wrench. Ron B. VK2OTC
2003 L322 V8 Auto
2007 Yamaha XJR1300
Post #683600 23rd Jan 2024 2:19am
