Home > General > Data & Statistics
Tommaso_in_UK
Italy
Data & Statistics
Every year a list of the most reliable brands, and models, is published somewhere.
1. Does anyone know how this data is collected? By whom?
2. Is any data available for Range Rover, subdivided by model/engine/production year?
On this forum the consensus on a thread was that the most reliable engine was the petrol SC 5.0 however, I am also interested in transmission, suspensions, etc. and I prefer clear cut data, rather than consensus.
Post #683347 20th Jan 2024 7:19pm
AndyRoo
Scotland 2012 Range Rover Westminster TDV8 Fuji White
Hi, I think you must be referring to the J.D. Power Survey. https://www.jdpower.com/
You can look up a particular car, but I think it's limited to the USA
Andy Fuji White / Jet 2012 4.4 TDV8 Westminster
Post #683350 20th Jan 2024 7:32pm
Tommaso_in_UK
Italy
Thank you, yes, something like that, even thought this is incomplete and does not rate for reliability which was my main interest.
Does anyone else know of any reliability ratings subdivided by engine/year?
The reason for my question pertains understanding which are the most reliable RR engines in the L322 lineup.
In another post there was a consensus that the petrol 5.0 SC was the most reliable, but I was hoping for data & stats.
Any help or comment would be apprciated
Post #683352 20th Jan 2024 7:59pm
mjdronfield
I don’t think you will find any specific data on reliability, just peoples possibly subjective findings on their specific ownership experiences.
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #683360 20th Jan 2024 9:22pm
Tommaso_in_UK
Italy
Thank you. It would be useful if forum members would offer their experience, on each engine. From wikipedia:
Petrol:
4.4 L BMW M62 V8 (2001–2005)
4.4 L Jaguar AJ-V8 (2005–2009)
4.2 L Jaguar AJ-V8 Supercharged (2005–2009)
5.0 L Jaguar AJ-V8 (2010–2012)
5.0 L Jaguar AJ-V8 Supercharged (2009–2012)
Diesel:
3.0 L BMW M57 turbodiesel I6 (2001–2006)
3.6 L Ford Lion V8 turbodiesel (2006–2010)
4.4 L Ford TD turbodiesel V8 (2010–2012)
Post #683373 20th Jan 2024 11:51pm
mjdronfield
The 5.0 non Supercharged was never available in the UK. 2011 Range Rover Vogue SE 4.4 TDV8
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #683375 21st Jan 2024 12:02am
CS
My 2004 322 had the BMW 4.4 petrol. It failed after 9 1/2 years and 97,000 miles, blowing coolant out of the back of the engine. It was a bit noisy at higher revs (I think BMW like that as "sporty") but smooth and pleasant enough otherwise. It is the only engine in one of my RRs that has failed and so I'd not recommend it.
My 2012 WM had the TDV8 4.4. It worked well and did not have the complexity of the later AdBlue system. I had no problems with the engine, nice torque for towing and pleasant to drive, 5 years and 57,000 odd miles. I was able to get the revs over 2,500 most trips so never had problems with oil accumulation in the second (higher rev) turbo. Not ideal if you do lots of short/low speed journeys.
My current engine is the 5.0SC (405). It has been fine, 6 years and 61,000 miles. Smooth and quiet at lower revs, refined, capacity for overtaking in a different dimension to the TDV8, picks up speed very effortlessly, one has to watch that to avoid licence problems. Power a bit much in some situations, e.g. quick exit from steep uphill and badly surfaced junction can have traction control coming on with winter/off road tyres. Note the 5.0SCs in the 322 and maybe the early 405s had plastic chain guides which can wear out, later ones have metal which are better. Performance/economy will be poorer in 322 given extra weight. Only Range Rovers since 1988
Post #683421 21st Jan 2024 1:50pm
Tommaso_in_UK
Italy
Thank you both for the useful insight. Looks like I should look for a 4.2SC
Besides marketing reasons, where there any other reasons why the L322 never received the 5.0SC?
Post #683440 21st Jan 2024 6:07pm
The 4.4 BMW lump in my '02 was just about the only bit that didn't fail on that car. Coolant issues leading to gearbox and transfer box issues, and endless electronic gremlins. In 4 years of ownership there was never a point when everything worked exactly as it should - though it remained mostly driveable - but had to be recovered half a dozen times. Sold on at 120k+ and the engine was still fine at that point.
The '56reg 4.2 SC served me very well for 5 years - no issues at all. Sold on to Quavey on here at 120k miles. He found a couple of things to do over the next year or so, but from memory nothing serious and he then sold on to a mate of his.
The '12 5.0 SC was very good for 4 years but the chains finally went at about 108k miles - and sold on here as a repairable. Only other issue I had over the 4 years was Aircon - needed new compressor and issues with that led to a new condensor and other linked bits. Mike - MPx
Post #683441 21st Jan 2024 6:26pm
AndyRoo
You can get the 5.0 in the states, if you don't mind a left hooker this has got to be the ulitmate in clean L322s.
California car, guaranteed not a hint of corrosion.https://www.ebay.com/itm/134892623567?hash=item1f683a16cf:g:epsAAOSwQnNlpXMj&amdata Fuji White / Jet 2012 4.4 TDV8 Westminster
Post #683442 21st Jan 2024 6:32pm
mjdronfield
This thread is in the L405 section, so might need moving.
I imagine the 5.0 non supercharged was never available in the UK as we had the 4.4TDV8 which I imagine would prob out perform it, so not needed.
The TDV8 was not available in the US so there was a gap to fill.
Take your time, you need to drive a few of the different engine choices, even if you are not keen on the exact car, it will help you decide which engine you prefer, and then narrow down your search.
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #683445 21st Jan 2024 6:42pm
Tommaso_in_UK
Italy
Yes, please, move it to the appropriate forum, I guess "general" ?
Easy to say: "drive a few engine choices" ... where ?
Post #683472 21st Jan 2024 9:24pm
mjdronfield
Stan will be able to move it.
I appreciate there aren’t that many places selling a variety of cars that have all the engines in, but keep an eye out near you and if something comes up, take it for a drive, you don’t have to buy it. It will help you narrow your search. The Vogue Centre usually has a few models in, but prob a good distance from you.
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #683474 21st Jan 2024 9:35pm
mjdronfield
https://www.thevoguecentre.co.uk/
Might be worth a day out to look at all the models, though they might have fewer L322s as getting older, so have a look at stock list and see if anything suits.
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #683475 21st Jan 2024 9:45pm
mjdronfield
Ah, they only have these 2, then the prices jump to £15000 odd…. Not much good then…
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #683477 21st Jan 2024 9:52pm
