Home > Technical (L405) > Stiff suspension issues |
GraemeS Member Since: 06 Mar 2015 Location: Wagga area Posts: 2469 |
Check that the tailshaft centre bearing mount is still as it should be, not broken or flopping about in the rubber. |
19th Jan 2024 7:32pm |
tuki Member Since: 28 Mar 2018 Location: Istanbul Posts: 22 |
bump.
18th Feb 2024 11:42am |
A front damper is just as likely the culprit as a rear, but possibly moreso because if oil has leaked from a front damper then it will be inside the air-spring, unlike a rear damper where the oil would be seen.
18th Feb 2024 8:01pm |
