Home > In Car Electronics (L322) > android system upgrade
JMC
Scotland 2012 Range Rover Westminster TDV8 Orkney Grey
I know nothing of the modern 'car play' systems and have no knowledge of Spotify etc, so I wonder if anyone can tell me this:
Can these systems give you internet on the car screen? If I want to watch glance at a live feed from a particular website while driving, will this system do that? Sorry for being a bit thick...... Embarassed The older I get, the more I realise that people confuse wrinkles for wisdom Smile
Post #681939 5th Jan 2024 6:31pm
garyRR
TorontoDee wrote:
Any chance there's a guide available for the dash removal process?
That and the cabin fan. A link to the part number or aftermarket model, and walk through for replacing it would be like Christmas coming early...
Yes, follow my guide on how to change the cabin fan. You remove the stereo anyway as part of the fan replacement.
https://www.fullfatrr.com/forum/topic67642.html 2015 Range Rover Autobiography 4.4 SDV8
Post #681999 6th Jan 2024 5:05pm
garyRR
Yes it will. The systems are basically a jazzed up Android tablet. You can install any apps like a phone from Google Play Store, Including Netflix, Spotify, YouTube, Chrome etc. To give it Internet access, you can either install a sim card or hotspot it to your phone.
Obviously a cautionary note to only use certain apps when not driving or whilst stationary. The voice control button on the steering wheel gets replaced with Google Assistsnt, so say you want to check a football score or ask a question whilst driving, you can always do this verbally. 2015 Range Rover Autobiography 4.4 SDV8
Post #682000 6th Jan 2024 5:10pm
mgrover
Wazzajnr wrote:
I bought one off Ali express, due to arrive 15th January and I'm planning to do a write up on fitting and how well or badly it works once installed.
if you get stuck on ought lemme know. did mine last year.
in grand scheme it was a doddle. taking dash off was hardest bit really.
actually a bit documented here:
https://www.fullfatrr.com/forum/topic63516-45.html Its actually a sport Sad
Not anymore, 4.4 TDV8 now Very Happy
Post #683100 18th Jan 2024 5:32pm
Wazzajnr
Thanks mg rover.
There are already things in the box that I don't know what they are and zero reply from the seller.
I'm sure it will be more apparent once it's all in bits but it's going to be a week or two as I'm working in Poland and Holland next couple of weeks.
Post #683103 18th Jan 2024 5:38pm
mgrover
ah no problems, it should come through to my email anyways, but tbf it was all plug and play which was awesome Its actually a sport Sad
Post #683159 19th Jan 2024 7:46am
bas1989
Netherlands 2011 Range Rover Autobiography TDV8 Santorini Black
Hey,
On the newer 12.3 inch android displays, will you be still able to change the analog/dashboard clock through the system? And do you need to change out the microphone with the one supplied or can you keep the OEM one and is the quality of phone calls any good?
Thanks
Bas
Post #684960 7th Feb 2024 2:55pm
mgrover
i used the aftermarket one cause wasn't sure how to tap into the stock mic.
the vid here shows the functionality of changing analogue clock
https://photos.app.goo.gl/hoD7UiBAM8ZaUgCt6 Its actually a sport Sad
Post #684961 7th Feb 2024 2:56pm
jlmiami
United States 2004 Range Rover HSE 4.4 V8 Epsom Green
Hey guys, any help on this? Thanks!
https://www.fullfatrr.com/forum/topic69407.html
Post #688477 20th Mar 2024 2:13am
