Home > In Car Electronics (L405) > Carplay & AA purchase. Looks very good Value
Page 3 of 3 <123
evotime
Only 5 is on.
The main issue is it only give sound on reading messsges when it feels like it. I dont use AUX as I can’t stream music so not an option for me. X5 40d
Post #682906 16th Jan 2024 6:58pm
silversurfer2
United Kingdom 2015 Range Rover Autobiography 5.0 SC V8 Corris Grey
Bosch or Harman Kardon?
Post #682907 16th Jan 2024 7:00pm
evotime
Bosch X5 40d
Post #682910 16th Jan 2024 7:08pm
silversurfer2
1,2,5 should be on
Here is the firmware file https://we.tl/t-M6g8FVPUnf
1. Find a U disk not larger than 16G (not SD card or cd card), format the U disk in FAT32 format
2. Copy the upgrade files and recovery110# to the root directory of the U disk
3. 30 seconds after the car is powered on, insert the U disk into the USB port of the decoder and wait for the upgrade
4. The entire upgrade process needs to wait for one and a half minutes
Best
Stewart
Post #682912 16th Jan 2024 7:18pm
evotime
If I have anything other then 5 on it won’t display on my nav or the scale of the display is off to the left. Took their tech guys some time to get it working.
Ok will try that once home at the weekend 👍👍
 X5 40d
Post #682915 16th Jan 2024 7:29pm
Custom10
Norway 2014 Range Rover Autobiography TDV6 Santorini Black
Thank you silversurfer2
Tom
Post #682920 16th Jan 2024 8:02pm
silversurfer2
I have seen that some people say their on / off is the wrong way round, have you tried only 1,2,5 OFF rest on?
Post #682924 16th Jan 2024 9:03pm
evotime
Can’t remember, I tried so many combinations to get it to work. Will need to try again. Hopefully an easy fix X5 40d
Post #682927 16th Jan 2024 9:07pm
Johnh
United Kingdom 2016 Range Rover Autobiography SDV8 Loire Blue
I have taken my unit out and gone for a separate screen for android auto. I have also got the original sat nav working with the map being displayed. The sound from the unit ok for sat nav instructions
Post #683348 20th Jan 2024 7:20pm
will308f
United Kingdom 2014 Range Rover Autobiography SDV8 Loire Blue
@stan where did you get your screen from please ?
thanks
Post #705524 27th Nov 2024 8:01am
Do you mean the unit I had mounted on the top vents?
If so I purchased from eBay....still got it somewhere. ... - .- -.
Post #705528 27th Nov 2024 9:03am
will308f
if you got both details great if not then just the unit
Post #705533 27th Nov 2024 9:49am
some info here,
https://www.fullfatrr.com/forum/topic20117-840.html ... - .- -.
Post #705539 27th Nov 2024 11:14am
will308f
Thumbs Up ,really torn between one of these and the total swap out
Post #705568 27th Nov 2024 7:46pm
Page 3 of 3 <123
