![]() | Home > Technical (L322) > Fuel Burning Heater Error Code 0x0304 Circulation Pump |
Andymac210 Member Since: 28 Feb 2020 Location: Wirral Posts: 5 ![]() ![]() |
Hi Nick, how did you get on with this fault, as I have the same issue ? |
nick4275 Member Since: 28 Sep 2018 Location: Bewdley Posts: 69 ![]() ![]() ![]() |
Hi Andy,
RoamingRange Member Since: 28 Jun 2015 Location: Cheshire Posts: 7 ![]() ![]() ![]() |
I also have this code and the FBH doesn’t seem to be working. I also have:
Hi Nick,
Hi Andy,
Lol, good luck |
So then Andy after having established you need hands the size of Snow White's mates for this job I have some info, but I've not fixed it as yet.
Todays update:
Well done for getting that far, where was the ATC unit located, and can you pick up a cheap one from ebay to test with ? |
The ATC is the climate control button assembly in the dash. The wires from the FBH coolant pump end up here. It's easy to get out of the dash and not too bad to disassemble thereafter. Mine was fairly dusty but nothing is jumping out at me on the circuit board.
So it's back together and things have changed - but I'm still no further forward.
I have actually changed out the ATC control panel in mine as I had a parasitic drain from the small fan inside it, I did not have to do any coding to the car at all. |
Sorry Andy,
johnty Member Since: 05 Jun 2020 Location: Yorkshire Posts: 5 ![]() ![]() ![]() |
I think the pump mounted on the fuel burning heater is driven by the fuel burning heater. Theres is a second pump if I remember correctly mounted under / next / near the diverter valve assembly. |
