Home > Technical (L322) > P0088-17 - Fuel rail/system pressure - 4.4 TDV8 2012
woodyrvf750
2012 4.4 TDV8
P0088-17 - Fuel rail/system pressure - too high - General electrical failure - circuit voltage above threshold (6Cool
Hi, I have this fault which causes restricted performance when the ignition is turned on, before the engine is started. I can clear the code with my GAP IID and the car drives fine.
I've changed the fuel pressure sensor and spliced in the replacement JLR connector to remove the suspect pressure sensor loom connector.
A local specialist have the car at the moment and changed the low pressure fuel pump. This has not fixed the issue.
They now say that the much more expensive high pressure pump needs changing but aren't able to give me a firm reason why they believe this is the case.
If you have any specific test that I or an auto electrician can do please let me know.
Post #682785 15th Jan 2024 2:50pm
jimmie
Poland 2004 Range Rover Vogue 4.4 V8 Epsom Green
Check delivery pump connector under hood
Post #682802 15th Jan 2024 5:24pm
GraemeS
Has the pressure regulator part number LR020692 been replaced yet?
Post #682814 15th Jan 2024 7:27pm
woodyrvf750
No, not yet..
Post #682818 15th Jan 2024 8:02pm
matthews
United Kingdom 2011 Range Rover Vogue TDV8 Buckingham Blue
Following as mine reads high on live data but obviously not enough to bring up a fault code .
Post #682824 15th Jan 2024 8:50pm
woodyrvf750
My local specialist seems to have fixed it.
First they tried the low pressure fuel pump under the bonnet. That didn't fix it.
Next they changed the high pressure fuel pump. That has fixed it. I hope it stays fixed as it's taking us to the Italian alps next weekend.
Post #684847 5th Feb 2024 9:44pm
