Home > Technical (L322) > CVD calibration or delete
nigor
Estonia 2012 Range Rover Vogue TDV8 Java Black
Hello
I bought back my old L322 4.4tdv8 my2011. Past owner did change rear shock absorber due to some accident. he said old ones blew up when he replaced some rear axle bushes... New shocks are also cvd shocks but it gives fault code from them, i wonder do they need to be calibrated? It causes special programs to be off, i took plug out of cvd module and now special programs work but there is still fault message.
I tried to disable cvd ccf with iid tool but it caused abs dsc etc stopped working.
Ride quality is good but yellow triangle in dash is annoying.
Post #682663 14th Jan 2024 11:01am
JayGee
Check continuity on the wiring and examine wiring at the top of the shocks as this is a common fail point. There is a reset function in the GAP IID tool if you replace the ECU module but not for replacing the shock units. 2012 TDV8 Vogue (L322)
Post #682672 14th Jan 2024 12:26pm
jimmie
Poland 2004 Range Rover Vogue 4.4 V8 Epsom Green
At the beginning take a look:
https://www.fullfatrr.com/forum/topic67977.html
iI it is real CVD then you have broken wire. Just replace cable and should be ok.
Post #682684 14th Jan 2024 2:17pm
JayGee
Ah yes I forgot about the 'fake' CVD's out there. 2012 TDV8 Vogue (L322)
Post #682686 14th Jan 2024 2:23pm
nigor
Aah then those are fake ones.
I changed ”Constant variable damping system” ccf from fitted to not fitted but yeah it gives loads of errors after that. Abs dsc ebd and so on
Any clues?
Post #682695 14th Jan 2024 2:58pm
nigor
I checked workshop manuals but couldnt find wiring diagram for active damping module. I tried to put 2.2ohm 5w resistor but it still gives C110E-14 and C110F-14
Post #683000 17th Jan 2024 3:31pm
GraemeS
Australia
https://www.fullfatrr.com/gallery/albums/userpics/15719/CVD~2.pdf
Post #683030 17th Jan 2024 8:45pm
