Home > Technical (L405) > Keyless entry switch off
ABAB
United Kingdom 2016 Range Rover Autobiography SDV8 Loire Blue
Finally got round to switching off keyless entry. Took a few goes until I found one helpful YouTube clip (link below) which said that the key programming procedure needs to happen with three seconds of opening a door. Wish I’d found that out sooner.
Anyway, here’s the exam question. Now that I’ve got keyless switched off, do I need to keep the car keys in a Faraday box at home any more? I realise that there are still all sorts of ways of baddies pinching a car, but specifically on the keyless relay hack that is well-publicised, is this now anything I still need to worry about?
?si=t4QUppC6nmcb9lMD 2016 SDV8 AB
Post #682581 13th Jan 2024 10:48am
when disabling keyless entry theres no need to use a faraday pouch.... ... - .- -.
Post #682583 13th Jan 2024 11:11am
knwatkins
Continue to keep your keys in a Faraday pouch or metal tin.
Whilst keyless entry stops them from unlocking the car, they could still use a relay attack to start the engine after they have smashed the window to gain entry.
And yes, I appreciate there are other other methods to starting the engine. It's always best to reduce risk. Kev
2014 L405 RR Vogue SE 4.4 SDV8 in Corris Grey
2010 L320 RRS HSE 3.0 TDV6 in Stornoway Grey
Post #682593 13th Jan 2024 1:56pm
Kot
Surely the "keyless entry" is the same as the "Relay" method? It is still the most comm on method that is used to steal L405 etc
Smashed window is a loud alarm, many tea leafs dont want that.
Then there is the visual deterrents, like stop lock and disqlock etc.
And of course a better immobilisers like Ghost 2, etc etc 2018 SE SDV8 4.4 Byron Blue
Post #682596 13th Jan 2024 3:01pm
Tinman
United Kingdom 2017 Range Rover Autobiography SDV8 Silicon Silver
Faraday box and or Ghost 2 anything to stop your pride and joy being stolen JLR are reprogramming the newer cars with different signal for the key as a recall. 2017 SDV8 4.4 silicon silver AB
2012 TDV8 4.4 Stornaway Grey AB
2011 TDV8 4.4 Buckingham Blue
2012 VW V6 3.0 Tougreg
Post #682605 13th Jan 2024 4:19pm
