Home > Maintenance & Mods (L322) > High Lift Wheel Ramps or Cribs
AndyRoo
Scotland 2012 Range Rover Westminster TDV8 Fuji White
Hi,
Has anone any experience or using high lift cribs (American Term) which are like next level ramps, sometimes stackable ? I can only find HD ramps that will lift by about 20cm
Apparently you jack up to one level, slip your cribs in, put wood sleepers under your jack and then jack up to the next level, insert crib tops. Seems they can take 3000lb & 30cm+ lift but they're really quite expensive and cant find these in the UK
Examples below or just search google images for car lift cribs
https://www.etrailer.com/Car-Ramps/Race-Ramps/RR-WC-12-2.html
https://myliftstand.com/
I made myself 4 of these wooden versions for my Audi but am nervous about using them with the weight of fatty. They're 30cm long, 19cm high and 18mm marine ply. Cheap, very solid and easily packed away, not sure if they'll take 2 tonnes though.
Anybody any thoughts on possible sources of strong "cribs" in the UK ?
Andy Fuji White / Jet 2012 4.4 TDV8 Westminster
Post #682556 12th Jan 2024 9:23pm
DrRob
I use heavy duty plastic ramps..
KATSU Plastic Car Ramps, 2 PCs Heavy Duty Garage Ramps for Lifting Automotive Vehicles Workshop Car Service and Repair 161918 https://amzn.eu/d/3dP2s1g Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #682558 12th Jan 2024 9:36pm
kevinp
You could always fill the gaps with more timber so that they are more or less solid.
Post #682562 12th Jan 2024 10:56pm
Alex1976
United Kingdom 2016 Range Rover Vogue TDV6 Santorini Black
I have these and they are superb (but not cheap)
https://cjautosheywood.co.uk/product/hydra...ity-cr012/
Post #682568 13th Jan 2024 7:28am
Epson Green
They look good but is 1368kg sufficient for lifting the front end? Kevin
2012 L322 Westminster 4.4 TDV8
1999 P38A 4.0 SE - Sold
Post #682590 13th Jan 2024 11:45am
AndyRoo
Thanks All, I'll keep looking around, I think I'll go for Rhino ramps, they seem to have a good rep
Post #682611 13th Jan 2024 3:50pm
chris_read
England 2009 Range Rover Vogue TDV8 Stornoway Grey
My solution was a few 6 foot long sleepers and a bit of time cutting at an angle with my chainsaw.
I made some long ‘ramps’ and some shorter ones which can go on top of the long ones to lift even higher off the ground.
The sleepers are 200mm wide so with 255 tyres you need to take time to position the car centrally. Oil changes were a doddle.
(Not my idea - I got it from another member of the forum). 2017 Jaguar F Pace 25t Portfolio - still part of the JLR family 😀
2009 3.6 V8 (MY2010) - my first ever diesel! - now also gone Sad
2004 4.4 V8 Petrol Vogue - now gone
Post #682621 13th Jan 2024 5:27pm
BigEnglishWagon
New Zealand 2005 Range Rover Vogue 4.4 V8 Adriatic Blue
Check out YouTube for the construction of the Cribs. Many different approaches and capacity.
Post #682758 15th Jan 2024 8:16am
