Home > Maintenance & Mods (L322) > Rear wash wipe mod.
Crispian22
Rear wash wipe mod.
I'm back in the fold with my recently acquired 4.2sc.
Having rebuilt the rear wash wipe a couple of weeks back due to it being full of crud and siezed up,I noticed the occasional drip from the inside,due to the crap design of the fluid running through the motor.
This led me to re-running of the washer fluid pipe,up through the top of the tail gate,(the pipe just fits when the top spoiler is refitted)and onto 2 x universal washer jets that snap onto the washer arm itself, hopefully increasing the longevity of the rear wiper and giving a much better spray of fluid on the rear screen.
I order the 2 items from Amazon, less than £20 all in and 30 minutes of my time.
Car Windshield Washer Hose Set 5m Rubber Universal Windscreen Wiper Hose With 30 PCS Hose Connectors Y I T Type Connect Car Water Pump And Nozzles Car Accessories Black https://amzn.eu/d/2hKrFhm
The Lord of the Tools 2pcs Car Front Rear Windshield Wiper Washer Nozzles Windscreen Washer Wiper Spray Jet Universal Car 4 Hole Window Washer Nozzles Fit for 8mm 9mm Wiper Arm https://amzn.eu/d/3FwFCUJ
Post #682515 12th Jan 2024 3:30pm
JayGee
Interesting. I find the stock jet system very poor as it's impossible to get the fluid to cover the screen properly and you either get not enough fluid on part of the screen or too much fluid that drips after the wipe has stopped 2012 TDV8 Vogue (L322)
Post #682517 12th Jan 2024 3:46pm
MR GLOVER
United Kingdom 2005 Range Rover Supercharged 4.2 SC V8 Buckingham Blue
Thumbs Up Thumbs Up
Post #682535 12th Jan 2024 4:51pm
pcourtney
That is much better, and a better design than JLR
Post #682537 12th Jan 2024 5:01pm
Jamesh7216
Thanks for posting this, I've carried out this modification on my RR today and not only will it extend the life of the wiper motor, the spray pattern on the window is much better
Post #683353 20th Jan 2024 7:04pm
JayGee
Treid to do this today in combo with replacing the high level brake light which is missing some pixels but the electrical connectors were corroded up and it will need more time. Did you push the hose out through the gromet for the camera or brake light as I wouldn't want to compromise weather sealing here as there are a lot of electrics in the inner upper tailgate. 2012 TDV8 Vogue (L322)
Post #683431 21st Jan 2024 2:25pm
Crispian22
Just pushed it up through the bigger hole and sealed it with silicone.
Post #683485 21st Jan 2024 10:33pm
Dragonoak4x4
United Kingdom 2012 Range Rover Westminster TDV8 Santorini Black
My rear wiper isn't working so I am going to be doing this mod once the new one arrives. Thank you for sharing 2005 D3 4.4V8 LPG
2012 L322 Westmister 4.4 TDV8
Post #683580 22nd Jan 2024 7:52pm
Dragonoak4x4
Did mine today thank you. Very staright forward and now gives my new wiper motor a chance to last 2005 D3 4.4V8 LPG
Post #686472 25th Feb 2024 10:24pm
Rambles
2011 Range Rover Vogue SE TDV8 Stornoway Grey
Would love to see a picture from the outside too…with hose attached to the 2 nozzles to see how that looks…..
Post #686480 26th Feb 2024 6:42am
BAZ8046
Hi,
This is how I did mine if that helps.
I also brought mine up through the spoiler housing by drilling a hole.
On mine the spoiler was squashing the pipe if I tried to run it out under the spoiler.
Definitely a good mod, I'm not sure who thought running the washer fluid through the motor was a good idea!
 2012 TDV8 4.4 Westminster Santorini black
2016 Discovery 4 Landmark
2002 Defender TD5
Post #686497 26th Feb 2024 3:57pm
Strider
England 2007 Range Rover Vogue SE 4.2 SC V8 Zermatt Silver
Crispian22
What a brilliant solution 10/10, my rear screen wash stopped working ages ago, however the wiper still works. Ordered those clip on screen jets that you have fitted plus tubing today.
Thanks
Post #686520 26th Feb 2024 7:32pm
Baltic Blue
Many thanks to the original poster.
I have joined the mod club this afternoon, and can definitely say my rear screen has never been as clean.
Please don’t tell anyone, but I have a confession to make.
The only difficulty I had doing the job, I couldn’t for the life of me get the centre M6 bolt back in the spoiler, maybe because I was so cold by that stage, so my rear spoiler is currently only held in place with the two end bolts.
Cheers and thanks
Mike.
 G reg 2.5VM Vogue Portofino red 1991- 1999
Post #686795 29th Feb 2024 3:33pm
Baltic Blue
Just an afterthought now that I have had a cup of tea and warmed up,
If anyone needs to replace the rear wiper arm and blade.
I suspect that the original part with the built in jets will be quite an expensive item, but by doing this mod it should be possible to replace it with a cheaper standard type arm and blade with no nozzles.
Post #686797 29th Feb 2024 4:49pm
I think if it were mine, I would wrap the arm/tube with fabric loom tape getting rid of the ugly cable ties... Thumbs Up
Post #686848 29th Feb 2024 11:51pm
