Home > Technical (L322) > Fuel door lock actuator |
JCW Member Since: 13 Apr 2013 Location: Cotswolds Posts: 873 |
I had a similar issue, where the locking ring that secures the tube that the locking pin sits in had detached from the hole inside the filler flap. As an aside, reinstalling that part requires pushing it forcefully into / against the hole whilst rotating it 90 degrees using the 4 small holes to gain purchase (I used a pair of straight circlip pliers that worked pretty well).
23rd Feb 2023 3:48pm |
gtzonone Member Since: 13 Aug 2022 Location: California Posts: 3 |
Thank you for the reply!
10th Jan 2024 4:07pm |
lschwarcz Member Since: 18 May 2019 Location: Hillsboro, OR, USA Posts: 273 |
So you got it to work? The fuel door lock on my '09 L322 has not worked for as long as I've owned it (about 4 years). After much diagnostics I finally found that this feature was disabled in the US spec models! WTF???
10th Jan 2024 7:05pm |
