Home > Maintenance & Mods (L322) > Transmission Fault Amber Warning
Sarchopperman
United Kingdom 2011 Range Rover Vogue TDV8 Epsom Green
A few weeks ago having been on a 25 mile run in my 2011 TDV8, I stopped and shut down the engine. On re-starting the "Transmission Fault" icon came on with subsequent loss of winter/off-road modes.
I have GAP tool. These are the fault codes;
TCCM-Transfer Case
P181D-00 (2F) Clutch actuator changeover solenoid - range/performance
P215B-62 (2Cool Vehicle speed/output shaft speed correlation - Algorithm based failure - signal compare failure
P279D-02 (2F) Four wheel drive range signal circuit - General failure information - general signal failure
I have cleared the fault codes a number of times but P181D and P279D always return.
I have checked the electrical connections at the Transfer Case and the ECU by the brake master cylinder. No corrosion or damaged wires. I have just replaced the battery.
I selected low range which engaged but then couldn't deselect High range. Using GAP tool and running Transfer case clutch calibration routine reselected High Range. It appears therefore that the High/low range solenoid is working.
I have no real idea what to do next. I have the diagnostic codes. The car drives normally and the transmission shifts normally. No erratic changes, no limp mode ......... all normal except no terrain modes.
Has anybody seen this before and managed to fix? I have trawled posts and there are many variations causing "Transmission Fault". The obvious culprit is the battery or alternator. The alternator appears to work fine and the battery is new (AGM 019).
I can only think to run the two Transfer Case Callibration routines? The transmission is shifting fine.
Any guidance / help would be welcome. I live near Aberdeen in Scotland and therefore Dartford Transmissions would be a bit of a trek. RR L322 TDV8 4.4 SE 2019 to present
RR L322 TDV8 4.4 - 2016 to present
Discovery 2 TD5 - 2010 to 2016
Discovery 1 - 2000 to 2010
Post #681954 5th Jan 2024 11:21pm
RRPhil
Just to clarify, what you appear to be calling the High/Low range solenoid is actually a ‘mode selector’ solenoid, which selects whether the shift motor works in either:
1) range change mode
or
2) clutch actuation mode
The range change itself is accomplished by the shift motor (also called the actuator)
For the P181D-00 DTC, Land Rover seem to be saying it could be caused by the mode solenoid or by the shift motor/actuator.
The pinpoint test defined for the mode solenoid basically consist of measuring its winding resistance
The shift motor/actuator testing is a little more complicated. Its connector has 7 pins.
Pins 1 & 8 (+ve & -ve respectively) power the motor itself
https://www.youtube.com/watch?v=S2I2WcIdF7Q
Although the transfer box has a separate sensor to determine the angular position of the shift fork, the shift motor/actuator also contains a Hall Effect position sensor, connected by pin 6 (Signal A) and pin 2 (Signal B). Pin 4 is for the temperature sensor and pins 3 & 7 provide the power (+ve & -ve respectively).
There are therefore a number of pinpoint tests for the shift motor/actuator, including tests for the motor :
and for the position sensor signals (A & B)
Phil
Post #682041 7th Jan 2024 2:01am
Sarchopperman
Hi Phil, what an amazingly detailed response. Thank you so much for taking the time to do this. I have my work cut out doing some testing.
The transmission has done over 180,000 miles with a mega flush at about 120,000 miles. As I say it continues to drive and shift perfectly fine. Is it not odd that it functions normally other than the loss of offroad/winter modes and that if low range is selected, high range cannot be re-selected?
Thanks again for your guidance, it's what this forum is all about! RR L322 TDV8 4.4 SE 2019 to present
Post #682049 7th Jan 2024 11:11am
Dolphinboy
Happy New year Phil.
And thanks again for still imparting your fathomless knowledge on this forum. Bow down Bow down Bow down
Post #682052 7th Jan 2024 11:28am
andryz86
Poland
@RRPhil, good afternoon. Tell me the voltage to the solenoid should be constant 12V. Should I turn off when changing bands?
Post #686411 25th Feb 2024 1:10pm
andryz86
Poland
I have a problem, the transfer case calibration is not going through. Calibration fails during the clutch calibration phase and a loud clicking noise is heard. Get into the high range.
Replaced the transfer case with a known good one. Everything remains the same, error p2789. From memory, earlier, when measuring SDD parameters, there was a constant 12V on the solenoid, everything worked. Now it constantly shows 6.4V. All current resistance and ground fault tests are normal and operational.
I would greatly appreciate any advice or help.
Post #686413 25th Feb 2024 1:21pm
ljbp
Portugal 2010 Range Rover Supercharged 4.4 V8 Baltic Blue
RRPhil wrote:
Just to clarify, ...
Phil
Thank you for this. Very informative
Post #704205 10th Nov 2024 7:14pm
