Home > In Car Electronics (L405) > Lost dashboard display
jaysta10k
United Kingdom 2014 Range Rover Vogue SE SDV8 Santorini Black
Hi guys anyone else experienced a temporary loss of the digital dashboard it lasted for about 5 seconds ran a scan with IID tool got this fault code P060A-08(2Cool internal control module monitoring processor performance - General failure information - bus signal / message failure
Any ideas as this has never happened before. Range Rover Vogue SE 4.4 SDV8 SVO Stying Pack
Audi A4 2.7 TDI S Line Black Edition phantomn black
Previous Cars
Range Rover Vogue SE Overfinch Styling 22" Elara's full black stealth colour coded
Java black Range Rover sport 2.7 TDV6
Alaska white Range Rover sport overfinch 3.6 TDV8
BMW M3 Carbon Black
Post #681915 5th Jan 2024 2:07pm
Kot
Maybe it's worth doing a battery charge? sometimes happens when battery is low and first start up of the day.
Presume the DTC cleared? 2018 SE SDV8 4.4 Byron Blue
Post #681919 5th Jan 2024 2:35pm
CS
It has happened on my car once, the instrument panel (i.e. the digital "clocks") went completely black for a while, then came back on again. There was a USA recall for certain 2017 cars (25.10.17) for exactly this, but the dealer here (a) had never heard of it (it not being on their computer which will be the extent of their research) and (b) the fault was not present or recorded when they checked it. It has not happened again. As the recall was just for 2017 cars then yours may be something different, but it would maybe be worth checking if a software update is needed and, as Kot says, it is always worth checking the state of the battery/electrical connections. Only Range Rovers since 1988
Post #681923 5th Jan 2024 2:45pm
jaysta10k
Hi don't think its battery related as I had been driving for about 2 hours when this happened and battery voltage when I checked yesterday while car running with IID tool was 14.6.
Cheers
Jay Range Rover Vogue SE 4.4 SDV8 SVO Stying Pack
Previous Cars
BMW M3 Carbon Black
Post #681924 5th Jan 2024 2:46pm
CS
The USA recall work on affected cars was a software update, so that is maybe the first thing to try. Only Range Rovers since 1988
Post #681951 5th Jan 2024 9:41pm
