Home > Technical (L322) > Side step problem
Squirrel
United Kingdom 2009 Range Rover Autobiography 5.0 SC V8 Galway Green
Side step problem
The motor on my o/s side step has seized. No problem, I have a spare...
Except the old one is seized into the bushing, so it's not simply a matter of removing it. I've tried, but I can't get it out.
So. I also have a spare front bracket. But there's a problem with that as well...
The pin appears to be jammed in that.
So does anyone have any ideas how to get the aluminium pin out without wrecking everything? Or does anyone have a spare sliding bushing that would fit? (Though this being a Land Rover part, I'll put money on the whole thing only being available as a unit.)
Any and all ideas most welcome. Thanks!
Post #681849 4th Jan 2024 10:23am
aluminium is a fairly soft metal so you could try drilling it out.. ... - .- -.
Post #681856 4th Jan 2024 1:39pm
Red Hot one
United Kingdom 2009 Range Rover Vogue TDV8 Stornoway Grey
Try a local blacksmith or metal working shop, they usually are very useful in extracting and manufacturing parts, certainly things like pins etc.
Post #681863 4th Jan 2024 4:19pm
Squirrel
Yes, I was thinking of drilling it out. But I don't seem to be able to manage it without damaging the sliding bushing. Is there any way of getting a replacement for that?
Post #681903 5th Jan 2024 9:36am
the trick to drilling is to drill a smaller diameter which leaves a thin outer sleeve of aluminium ..you then collapse this sleeve inwards ... ... - .- -.
Post #681905 5th Jan 2024 10:31am
DrRob
Or chuck the whole side step assembly in the skip 😂 Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #681909 5th Jan 2024 12:27pm
Ramblin Man
England 2012 Range Rover Vogue 4.4 V8 Buckingham Blue
Hi @Squirrel; Thanks for posting this; I am planning a refurb of my side steps soon as the drivers side, which is obviously used the most, is developing a jerky action. I’m interested to know how your refurb goes so please keep us all updated.
Please would you be able to share the part number of the electric motor as I’d like to price up a replacement.
Also, would you happen to know if the motors are handed or can they be swapped over from O/S to N/S and visa versa ? TDV8 4.4 2012
Post #682042 7th Jan 2024 6:40am
Fla
Ireland 2012 Range Rover Westminster 4.4 V8 Zambezi Silver
@ Squirrel
Did you manage to get the old motor removed? I dismantled mine at the weekend to find my motor had let in water so I too need to replace it. I dont think these can be removed manually so Im going to try a 20 tonne press to see but its not ideal as mine already have cracks in the castings which I need to weld up.
@ Ramblin Man
The motors are on ebay, I think £200 in your money so not too bad Current yokes
2012 4.4 TDV8 Westminster
2006 Disco 3
Scoobie GT wagon
Mx5 G Ltd
TT S Line
Pajero JDM Exceed
Post #682133 8th Jan 2024 9:43am
I replaced a step motor and it was a hell of a job! It's an interference fit and I ended up cutting the bracket off around it (very carefully) with an angle grinder! It also has a flat on it, which makes it even trickier.
Good luck with the press Thumbs Up Got - 2017 SDV8 Autobiography in Loire Blue
Post #682134 8th Jan 2024 9:55am
Squirrel
@ Stan
Cheers, that sounds like a plan. This can be done without damaging the bushing?
@ DrRob
Oi!! I like my side steps. Rolling with laughter
@ Ramblin Man
I'll look up the part number for you when I go out to the car - I've just got it back from the garage. I've got a shiny new motor for the O/S, but no way of fitting it as yet!
There are two different motors, I'm afraid, one for each side.
@ Fla
Nope. I wasn't going to try, I've got a spare bracket but that has the pin wedged in it. We tried getting the motor off the old bracket just in case, but same problem there.
@ alanm_3
Thanks! I'm just going to leave it for now until I have some more time - I've spent ages messing with it this past couple of weeks. My garage has offered to fit fixed side steps to replace the deployable ones - not a chance!! Shocked
Post #682154 8th Jan 2024 3:47pm
Squirrel
If anyone is interested - I've just found side step brackets for the L322 on AliExpress. From China. Embarassed I doubt they're any good, but I've ordered one anyway, just to see what happens. I'll keep you posted.
Post #682161 8th Jan 2024 4:32pm
Squirrel
Hope this helps!
Post #682232 9th Jan 2024 12:26pm
Fla
Are the late L322 motors and the L405 really that different. They look very similar. I can find loads of L405 copies on euro sites but all the ones for the L322 (LR004807) are all genuine and stupid money. I have found a pair on uk ebay which is £200 plus shipping plus £70 import charges so roughly €400, which is a bit high
Thanks Current yokes
2006 Disco 3
Scoobie GT wagon
Mx5 G Ltd
TT S Line
Pajero JDM Exceed
Post #682242 9th Jan 2024 1:35pm
Squirrel
I don't know about the motors, but the brackets look quite different. I'd put money on LR altering the motors slightly between the two variants so that one doesn't fit the other.
Post #682317 10th Jan 2024 10:36am
Squirrel
If anyone's interested, I resolved the problem by buying a part off AliExpress - £76. It wasn't perfect and required a bit of fiddling with the motor to get everything to fit, but I now have two fully functioning side steps. Cool
Post #683990 26th Jan 2024 4:57pm
