Home > Maintenance & Mods (L405) > Retrofit wading sensors
ChrisJC
United Kingdom 2014 Range Rover Vogue SDV8 Aintree Green
Evening All,
The recent floods got me thinking. My L405 does not have the wading sensors. This means that when I go in deep water, I have to open the window and lean out to see how far up the front wheel the water has come!
Does anybody know what is required to retrofit the wading depth sensors?
I believe it is done with cameras in the wing mirrors, but is it part of a greater system?
Any ideas?
Thanks,
Chris. L405 - 4.4SDV8 Vogue
P38 - 4.6V8 HSE
Land Rover series IIA V8
Post #681879 4th Jan 2024 10:17pm
DrF
United Kingdom 2013 Range Rover SVAutobiography 5.0 SC V8 Orkney Grey
I have it on mine, it actually doesn't tell you how deep you are, but it does indicate when you are reaching limits apparently!! I am not brave enough to find out!! It's a good toy though. Good luck, I am sure its quite a mission to install software plus hardware but jolly good luck Thumbs Up
Post #681894 5th Jan 2024 12:44am
luxmoggy
Germany 2019 Range Rover Autobiography SDV8 Montalcino Red
This place offers to fit it.
https://www.lr-chip.co.uk/car/range-rover-...#retrofits
Reading their page:
As far as doing it. New mirror housing - which includes the space for the sensor. The 2018-2020 car might have the wiring and if you have the adaptive cruise control and the 360 camera. Then you only need to activate this in the software.
Looking at their other changes, it is expensive. e.g. 100 pounds to change the stop/start.
I did this with the IID tool. SDV8 AB MY 2020
MINI Cooper S Cabrio
Kit: Jaguar XK140 (in progress - the website is link to build)
Post #681906 5th Jan 2024 11:54am
Ryanmt
United Kingdom 2017 Range Rover Autobiography SDV6 Santorini Black
I assume its only an option for 2018+ cars. Was the wade sensor even an option on the earlier l405's?
Post #681928 5th Jan 2024 4:37pm
DrF
Yes from 2014
Post #681930 5th Jan 2024 4:44pm
nambFFRR
United Kingdom 2016 Range Rover Autobiography SDV8 Corris Grey
Interesting reading and something I’m going to follow up. I suspect it’s all retrofit kit as it’s moving from rear parking to proximity rear parking systems. I found the wiki info very informative so for the price quoted, it should be a fairly easy (haha) retrofit
One to note....the wade function doesnt work if you have fixed or deployable step according to the literature L405 2016 4.4SDV8 Autobiography Corris Grey/Pimento - Current
L322 2011 4.4TDV8 Vogue SE Alaska White/Charcoal - Gone
and lots of other none LR stuff…..
Post #683663 23rd Jan 2024 3:22pm
