Home > Technical (L322) > L322 rear light out
tymh
United Kingdom 2008 Range Rover Vogue TDV8 Tonga Green
L322 rear light out
Over Christmas, my rear near side (left) tail lights has gone out. Checked the voltage and there's less that 0.2 V getting to it. Offside is fine. Is this a fuse issue, or something else? If it's a fuse - which one please?
Easiest fix is to run a wire from the RHS to the LHS to at least this one has power, but that's a last resort. Tym
(current) L322 3.6 TDV8 Vogue 2008 Tonga Green
(previous) L322 4.4 LPG Vogue SE 2003
If it sticks, force it. If it breaks, it needs replacing anyway.
Post #681778 3rd Jan 2024 3:44pm
grayst01
Scotland 2012 Range Rover Vogue 4.4 V8 Java Black
Hi, i found this issue one time was related to the rear reg plate bulbs Shocked I renewed these and the rear light worked again! Not sure why, but I think it was to do with the reg plate LEDs… Rolling Eyes Cheers, Steven.
2012 Vogue 4.4 TDV8.
Post #681818 3rd Jan 2024 9:38pm
tymh
RHS and number plate lights are fine. Every light has been replaced by led except dipped headlights. Tempted to run a wire from right to left just to get power to it. Tym
Post #681819 3rd Jan 2024 9:40pm
