Home > Off Topic - Other Cars > Any Knowledgeable Tyre Guru’s On Here Please? |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8335 |
My thoughts would be that if you have to ask the question, you know the answer Craig. Will you feel happy at those sorts of speed with tyres that you think may not be a good idea to use.... Pete
1st Jan 2024 4:40pm |
DrF Member Since: 30 Jun 2014 Location: South East Posts: 1433 |
Craig, not sure what model you have, but my 2018 Vanquish S has pirelli tyres, they are specific to the Vanquish S, I would steer clear of anything that's not designed specifically for the car personally. Tyres might fit but are they recommended is the question? especially if speed is your aim. I know with Vanq s the Pirelli was specifically developed for the set up of the car. They have an AML code on them.
1st Jan 2024 4:59pm |
Dixy Member Since: 09 Apr 2009 Location: Somerset Posts: 1098 |
Whilst I am a strong believer in the tyres are the only point of contact between you and the road, for on road driving with premium brand manufacturers I doubt even on an autobahn you come any where near to the point of making a difference. letters not necessarily in the right order |
1st Jan 2024 6:12pm |
Alistair Member Since: 11 Feb 2011 Location: Peterborough / Bordeaux / Andorra Posts: 7964 |
I've leant this lesson the hard way......
1st Jan 2024 7:16pm |
Bean19844 Member Since: 25 Oct 2020 Location: Essex Posts: 929 |
Mixing tyres is OK within reason mate on any car. As long as your getting very similar tyres and your not sticking winter tyres on the back and summer tyres on the front. Me personally on a car like that, I'd change all 4 of them in one go, get the other two tyres back and flog them off on ebay so you'll get something back for them |
1st Jan 2024 9:00pm |
Rex the RR Member Since: 15 Nov 2019 Location: Perthshire Posts: 43 |
Think it's all been said, for high performance cars, don't mix tyres across axles and stick to what the car manufacturer recommends! There has probably been a lot of testing carried out! I run cup 2's but mainly in the dry and occasionally on track. Also, if l remember correctly, they have a tread depth of 5mm from new. Not great if your mainly touring! |
1st Jan 2024 9:17pm |
Cam-Tech-Craig Member Since: 03 Aug 2011 Location: Gloucestershire Posts: 16302 |
To fill in some gaps, the car went into Bamford Rose a month or so ago and when I collected the car Mike said “that’s very lively in the handling department! When was the last time it was set up?” As it’s the only DB9 I drive and Mikes the AM professor! I take it on the chin and off I go to our nearest hunter machine and sure enough only one of the little boxes are not RED!!! Ooooops! 🤬 and away the boys go removing the floor and adjusting everything back to perfect!
1st Jan 2024 10:27pm |
Gremlin500 Member Since: 11 Mar 2022 Location: Newcastle, UK Posts: 1551 |
Hi CTC,
1st Jan 2024 11:38pm |
dingg1 Member Since: 29 Jun 2013 Location: PORTUGAL Posts: 1348 |
"That said, at road speeds, and assuming the car will not be tracked, or driven in a manner not to endanger other road users, perhaps this is all a bit acedemic? Whistle Twisted Evil"
2nd Jan 2024 12:02am |
Thanks for all the answeres guys... Much appreciated... |
2nd Jan 2024 2:18pm |
dhallworth Member Since: 10 Oct 2011 Location: Glasgow Posts: 3133 |
Everyone has their own thoughts on this subject, so, here's mine
2nd Jan 2024 3:31pm |
Pawl Member Since: 07 Nov 2017 Location: West Midlands Posts: 696 |
Tyre sidewall stiffness can vary significantly between brands & specific tyre variants - even on low profile tyres - which if different front rear can lead to some very wierd initial cornering "turn-in" behaviour - especially on something as heavy as an Aston.
2nd Jan 2024 7:18pm |
Mikey Member Since: 10 Jan 2008 Location: Dundee Posts: 1778 |
My XFR came with well worn Nankangs, and it was horrendous in the wet Some brand new Conti's went on, and it wasn't much better. Suspect that was something to do with the 500bhp |
2nd Jan 2024 8:14pm |
evotime Member Since: 02 Apr 2021 Location: Aberdeenshire Posts: 134 |
Michelin Pilot Sport 4S, fantastic tyre. Stick them on the rear and then change the fronts to the same as soon as you can I would suggest X5 40d |
3rd Jan 2024 12:00pm |
