![]() | Home > Technical (L322) > 3.6 td v8 2007 crank case breather |
Dutchgit Member Since: 17 Sep 2023 Location: Emmerich am Rhein Posts: 178 ![]() ![]() ![]() |
Open bonnet, take out the engine cover, take out the vent box (technical term) just two 13mm head nuts. Undo 2 10mm head nuts and one bolt for the aluminium pipes (aircon?) and tie them up out of the way.
I bought a new membrane, the old one was somewhat stiff, be careful prying open the tabs and best warm it up so the plastic don't break as easy. You can also just buy the whole breather which I think is around 90 quid. |
horsedentist Member Since: 23 Jun 2017 Location: london Posts: 158 ![]() ![]() ![]() |
Thanks for that did you replace it with a new one or just clean the old one ? |
Cheers thanks for that |
Put a new new membrane in as I'm a cheapskate. It did take some time to get here as I comes from the Ukraine. (about 2 weeks) It wasn't dirty at all inside. |
