![]() | Home > Maintenance & Mods (L322) > Cleaning Interior Plastics |
supershuttle Member Since: 20 Mar 2011 Location: Lancashire Posts: 3868 ![]() ![]() ![]() |
Am I safe to assume that the plastic trims, doors, dash etc are completely through coloured - not painted and I can give them some very aggressive cleaning.
I just used a Magic Sponge to clean the plastic on my doors and dashboard and the results are amazing, no hard scrubbing required and every thing came up like new . 2008 MY Supercharged
ric355 Member Since: 02 May 2011 Location: Surrey, UK Posts: 302 ![]() |
I have just used some of this on the top of my doors where there is ingrained dirt from elbows etc today.
Rob2529 Member Since: 22 Nov 2010 Location: Wirral, uk Posts: 1470 ![]() ![]() ![]() |
Geoff- let rip with some bathroom cleaner. I did mine with some grim and lime remover over 12 months ago and there fine! Came up a treat but need cleaning again now. Just make sure you use loads of water to clean it off as long term might cause some issues. |
claud Member Since: 15 Apr 2009 Location: Godalming Posts: 103 ![]() ![]() ![]() |
For the gentle approach, try Autoglym Upholstery Cleaner! 2018 Range Rover Autobiography
RRUK Site Supporter Member Since: 08 Jun 2007 Location: UK Posts: 6373 ![]() ![]() ![]() |
On plastics you'd be amazed what a normal nail brush and warm water with fair liquid can do. Discovery 4 HSE
Gave it a good scrub - passenger door came up a treat - like new. Drivers door is a whole different kettle of fish, it's been painted! I think maybe that the leather armrest/doorhandle was worn so that got a recolour, fine, but they have kept going and sprayed some of the door panel to maybe blend it in there is even overspray if you look closely. What where the |
Vogue Member Since: 31 Jan 2008 Location: on the hill Posts: 3758 ![]() ![]() |
i'd avoid cellulose thinners, it dissolves certain plastics - to my cost - white spirits is ok on plastic, but not sure if it will remove dry paint. |
If it's on the plastics - and it's coloured right through, try duraglit (brasso). Land Rover Addict
gingerbiker Member Since: 06 Dec 2010 Location: North Yorks Posts: 26 ![]() ![]() |
+1 for autoglym leather cleaner for interior plastics, but baby wipes clean most day to day car grime up of the interior really well
Saw and bought a new complete door trim on fleabay for £100 - seemed like the shortest distance between two points - but thanks for all the advice |
I'll echo an earlier sentiment.....
Too good to be true, couldn't tell from the picture when it arrived the trim was stunning but finished entirely in leather so it didn't match the others - sent it back ![]() |
