Home > Technical (L322) > Windscreen misting up |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8275 |
Have you got the aircon on, this dehumidifies....
28th Dec 2023 12:33pm |
Herald Member Since: 10 Aug 2016 Location: Surrey Posts: 16 |
AC on all the time, never turn it off. Even with the AC on it is struggling to stay clear, mists up when parked and takes an age to clear when setting off unless I activate the heated front screen. This is a significant departure from normal and having owned the car for nearly 6 years, it’s definitely not right now.
28th Dec 2023 12:40pm |
Baltic Blue Member Since: 13 Aug 2015 Location: North Wales Posts: 3776 |
The A/C drains under the car and usually leaves a little puddle.
28th Dec 2023 12:52pm |
I think it’s the correct way up, the air flows in the direction of the arrow. Interesting thought though thank you, what difference does it make to the water ingress? It looks like it is symmetrical too to bottom so I always assumed the flow was a filtration thing not a water issue. |
28th Dec 2023 1:04pm |
JavaBlack Member Since: 07 Sep 2016 Location: UK Posts: 67 |
It might be worth removing the pollen filter housing and checking the seal to the bulkhead isn’t deformed. |
28th Dec 2023 1:05pm |
Water is allowed into the pollen filter housing and the drains are free flowing. Doesn’t seem designed to seal? |
28th Dec 2023 1:18pm |
cass Member Since: 12 Oct 2011 Location: northumberland Posts: 745 |
Is the AC working OK? Does it need serviced? |
28th Dec 2023 2:15pm |
nicedayforit Member Since: 11 Jun 2011 Location: Beside the Solway Posts: 3978 |
I’d be inclined to have a look under your front carpets. |
28th Dec 2023 2:25pm |
It gets cold perfectly OK. It doesn’t get warm at all quickly. So I’m presuming that as it gets cold OK, the dehumidifying effect is still working as the two are inextricably linked. |
28th Dec 2023 2:26pm |
Done that! Lifted them and all dry. First thing I did. |
28th Dec 2023 2:27pm |
