Home > Technical (L405) > Mystery loss of power HELP
Jamiefullfattr2017
United Kingdom 2017 Range Rover Autobiography SDV8 Mariana Black
Hi everyone, pulling my hair out with an ongoing issue that seems to be undiagnoseable.
I have a 2017 4.4sdv8 57000 miles,
Driving around normally keeping the revs below 2500rpm everything is all fine and dandy, however take it above those revs when the 2nd turbo kicks in whether thats booting it or not the car just becomes bogged down and loss of power but you can momentarily feel the 2nd turbo kick in then it just becomes flat as a fart. even if you manually change up a gear dropping the revs back below 2.5k until you lift of the throttle 2-3 seconds then everything returns to normal. Take the revs back upto 2.5k and same again, does it when cold and warmed up. The only thing that changes is a loss of power and a change in the engine note.
Been plugged in to diagnostics no faults at all, have read live data 2nd turbo boosting and operating normally, the car seems to think everything is happening but its not?
Becoming frustrating and wondered if anyone had any ideas on what could be causing this? Or what else to check?
Many thanks, jamie
Post #681152 25th Dec 2023 12:07am
What diagnostic tool has been used, and who did it...?? Pete
Post #681171 25th Dec 2023 2:44pm
Jamiefullfattr2017
Hi pete, think it was a solus pro and a good friend i know, we both sat in the car and went for a drive around monitoring all live data.
Only thing we noticed with the bonnet up in the air and engine cover off was a mechanical chainy type noise coming from what i think is the hpfp not sure if this is normal or not?
Its almost like a boost pipe collapsing and being starved of air or not getting enough fuel but surely both of these would cause some sort of dtc fault?
Post #681177 25th Dec 2023 6:57pm
Just checking on the scanner you used, the Snap On Solus are good so should show something...
Very weird, I would guess fuel and it does sound like a HPFP issue but it's above my pay grade.... Pete
Post #681183 25th Dec 2023 9:38pm
Jamiefullfattr2017
Thanks for your advice pete, its a very strange issue and driving me insane!
Ill take another look at the live data and focus again on fuel pressure readings 👍
Post #681184 25th Dec 2023 9:41pm
fisha
Could it be an air flow meter ? I think that each of the turbos has its own air inlet route which is joined after the turbos on the way to the throttle body an plenum. After each of the air filters on each side there are sensors plugged into the pipework. Whilst I’ve never checked, I’ve presumed them to be air flow meters.
If the MAF for the large second turbo isn’t reading quite right , that could explain the bogging down. For example, when the 2nd turbo spools up and starts drawing air across the sensor, the sensor is sending a low reading cause it’s not working correctly.
The ecu then may see high pressure at the plenum (cause the turbo is working), but low air flow … so might deliver less fuel than is actually needed, and the performance dies.
The scenario may not throw errors as the sensor may be sending a value within spec … just the wrong value for the actual airflow. ( although re reading your post does say you were looking at the turbo values … sorry )
May be worth looking at the air flow readings as you the second turbo kicking in. V8 or else ...
Post #681195 26th Dec 2023 9:43am
Jamiefullfattr2017
Hi fisha,
Certainly worth another look! Thanks for your reply. Im hoping in the next day or so to get someone who understands the live data allot more than we did to take a look but i will keep you posted 👍👍
Post #681196 26th Dec 2023 9:51am
