Home > Technical (L322) > Parking Assist 4.4 TDV8 2011 Model
Dstew
Parking sensors stopped working.
Nothing happening at all. No light on at dash switch. Reverse camera works as it should.
Code reader says U0159 Lost communication with parking assist control model.
Is there a fuse that could be culprit? Or is it likely the module? Or something else.
No idea where the module even is..
Thanks in advance
David
Post #681103 24th Dec 2023 12:10pm
Baltic Blue
Parking aid module.
Everything you need to know is covered in detail in the workshop manual, which is available as a free download from Wiki.
Post #681110 24th Dec 2023 1:54pm
JayGee
Common failure is by water damage - open up the case and check.
 2012 TDV8 Vogue (L322)
Post #681121 24th Dec 2023 4:11pm
