![]() | Home > Maintenance & Mods (L322) > Rear Wheel Arch Rust MY04 and ideas to patch up please |
Jamesh7216 Member Since: 30 Dec 2021 Location: Baschurch Shropshire Posts: 37 ![]() ![]() ![]() |
Wheel arch repair panels are available, there's a number of suppliers on ebay right now selling them, I did mine last summer buying from one of the suppliers there |
pcourtney Member Since: 14 Jan 2020 Location: Stansted Posts: 836 ![]() ![]() ![]() |
Found them
Noted - thank you- will alert the body shop that is down the road from me ![]() |
A body shop should already know that, I mentioned it in case you were looking at a DIY solution.
ouch, it looks like the Car Panels product does not go down to the sill of the car, it stops at the green line shown below - they obviously didn't get much info or feedback from many of the suffering 20 year old L322 owners that have this very common problm - stupdity at its highest level !
why would they stop just short of the sill, does anyone know if these panels can actually be placed down to the sill, and not use the upper half - basically I only need the last 6 to 8 inches ?? |
Yes just cut off what you need after you have removed paint from the existing wheelarch to see where the rust stops and you will be welding to clean metal |
good to know, I just about have enough clean metal up the wheel arch to do just exactly that James, thank you ! |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8354 ![]() ![]() ![]() |
Those arches are to fix the rust that develops at the top of the arch just next to the door...
OMG Pete, that's highly impressive work on that old Datsun - so skilled and talented !
The fronts are usually OK, if not dig deeper before you order the panels....
