Home > In Car Electronics (L322) > android system upgrade
kinhellmick
United Kingdom 2007 Range Rover Vogue TDV8 Barolo Black
hi all was looking for recommendations on upgrading the in car entertainment system on my 07 l322
the old system is the main cause of my battery drain issue i have been having for the last year.. so looking on replacing screen, amps dvd player etc to an android system to eradicate the problem but realise its not as straight forward as it would have been on a earlier model ( fibre optic cables etc.).. any suggestions on units out there on the open market greatly appreciated
just an update whilst searching for units ..found this guy whos advertising a unit for my year anyone had any experience or used this unit..cant get in touch with him untill 4th of january
https://www.ebay.co.uk/itm/403742665849
Post #680932 22nd Dec 2023 11:23am
Fla
Ireland 2012 Range Rover Westminster 4.4 V8 Zambezi Silver
Im interested in this myself. I didnt realise the head unit etc could cause battery drain. Ive a big drain somewhere as my battery is always on 1 bar when I put the charger on.
In my disco I installed a Carpuride and found it great but as you say the RR is a different beast. Ill follow with interest. Current yokes
2012 4.4 TDV8 Westminster
2006 Disco 3
Scoobie GT wagon
Mx5 G Ltd
TT S Line
Pajero JDM Exceed
Post #680933 22nd Dec 2023 12:15pm
Dutchgit
Germany 2008 Range Rover Vogue TDV8 Stornoway Grey
Can't remember where I've seen or read it but it's indeed pretty involved and apparently requires wires to be run from the new head unit to the rear of the car where many of the components are found of the current stock set up.
Post #680977 22nd Dec 2023 8:13pm
garyRR
Climate and Head Unit:
Head Unit Only:
Split Screen View:
(split screen view with Google Maps and Spotify)
2006 onwards uses the existing looms and DSP, so no need to run cables to the rear. However, it's still a major job to change the screen. If not done already, it's worth using the opportunity to replace the cabin fan. 2015 Range Rover Autobiography 4.4 SDV8
Post #680989 22nd Dec 2023 11:06pm
bogdan xtr
Romania 2008 Range Rover Supercharged 4.2 SC V8 Stornoway Grey
What brand is that? The 4x4 menus and trip are still available? Is it on 2 ohms?
Thanks
Post #681010 23rd Dec 2023 1:45pm
garyRR
There's no 4x4 menu on 2010-2012 cars. I can't confirm for 2006-2010 that don't have the digital dash. It supposedly supports it but on 2010 onwards cars it is not programmed in. 2015 Range Rover Autobiography 4.4 SDV8
Post #681024 23rd Dec 2023 5:16pm
TorontoDee
Canada 2012 Range Rover Westminster 5.0 SC V8 Santorini Black
Edited: off topic question addressed via PM. Smile 2012 Supercharged L322
Post #681053 23rd Dec 2023 8:45pm
Phoenix
Post #681056 23rd Dec 2023 8:57pm
AndyRoo
Scotland 2012 Range Rover Westminster TDV8 Fuji White
Hi,
2012 L322s do have the 4x4 status display, I can select via the head unit for the main display but it wont appear in the dash display unless you select an off road mode.
What brand of head unit is the full width one shown above, I've seen a couple of differnet types on flea bay but I'd rather go with something that has this forums experts approval as confirmed as viable on an L322 without having to rebuild the entire interior.
Cheers
Andy Fuji White / Jet 2012 4.4 TDV8 Westminster
Post #681167 25th Dec 2023 12:03pm
garyRR
It's the Aoonav system. Android 12. 8GB RAM 128GB ROM. 4G, wireless Android Auto and Apple CarPlay.
I added a 4G sim, which in my view is well worth it, as I primarily use the head unit itself for sat nav, Spotify, Google Assistant etc, which I find much more usable than CarPlay/Android Auto. It also means all the apps keep up to date.
There's no 4x4i (the name of the app) on this screen for 2010-2012 cars (my assumption is that it gets excluded as the digital driver display shows the same information - don't be fooled by any advert showing the 4x4 infographic. I checked with 10+ sellers when i bought mine and all confirmed the app isnt programmed in for 2010-2012 cars). For 2006-2010 cars I cannot confirm.
Changing the head unit in an L322 is a dash out job (i will add a point that it is only a dash out job in order to access the screws to release the existing head unit, not because of any reconstruction or re-wire). The plus side - the new screen fits on a logically designed mount, meaning future head unit removal is done by 4 screws behind the screen, without needing to remove the whole dashboard. I wish Land Rover had that kind of know-how!
Each to their own, but at half the cost of the Navitech (or similar) CarPlay system, a 12.3" screen with high resolution graphics was a no-brainer for me, and brings the cabin right up to date.
One final observation: the sound quality from the Harmon Kardon system is significantly improved. 2015 Range Rover Autobiography 4.4 SDV8
Post #681188 26th Dec 2023 12:07am
That looks very good.... Thumbs Up Pete
Post #681191 26th Dec 2023 12:42am
AndyRoo
Many thanks for that, I'll add to my wish list once I've paid the vig to Santa's henchmen.
Cheers
Post #681198 26th Dec 2023 12:07pm
Wazzajnr
I bought one off Ali express, due to arrive 15th January and I'm planning to do a write up on fitting and how well or badly it works once installed.
Post #681731 2nd Jan 2024 8:44pm
TorontoDee
Any chance there's a guide available for the dash removal process?
That and the cabin fan. A link to the part number or aftermarket model, and walk through for replacing it would be like Christmas coming early... 2012 Supercharged L322
Post #681916 5th Jan 2024 2:12pm
AndyRoo
Hi,
There a couple of guides on Youtube on how to strip the dash to get to the headunit, this is one of the better ones in my opinion
Post #681920 5th Jan 2024 2:40pm
