Home > Technical (L322) > EGR restricted performance
Triumph72
United Kingdom 2010 Range Rover Vogue SE TDV8 Ipanema Sand
Hi,
Going into restricted performance shortly after driving off, I found no difference in engine power,
the codes are
P045C-00 - Exhaust gas recirculation B control circuit - Low (2F)
P140E-21 - Exhaust gas recirculation position sensor C minimum/maximum stop performance - General signal failure - signal amplitude<minimum (28
I was just wondering if anyone knows what side of the engine the codes are for ?
I cleared the codes several times now but it always returns
Post #678497 22nd Nov 2023 12:18pm
LASBAM
Germany 2007 Range Rover Vogue TDV8 Orkney Grey
Hi,
looks like your EGR Valve has a small defect with the electrical adjustment.
TWO ways to get it fixed
- Delete the EGR's with a Software patch and blind them mechanically
- Replace the defect EGR Valve unit (wO the Cooling)
Good luck! Current:
- 2006 RR L322 - 3.6 TDV8
- 2022 MB AMG GT BS
- 2020 Audi Q2
Past:
- Ferrari California 30
- 2018 Abarth 595 Competizione
- 2009 Porsche Cayenne Diesel
- 2010 MB E500 Coupé
- 2005 Porsche 996 Turbo
- 2002 Porsche Boxster 986 S
- 2001 Audi S8
Post #679261 1st Dec 2023 9:32pm
Phoenix
Post #679262 1st Dec 2023 9:51pm
Triumph72
I finally got to use my Garage after my son removed his car.
Removed the inlet manifold to have a look at the EGR valve,
stripping it down I noticed that the valve was not closing properly,
it had built up rust on the shaft and wouldn't let the valve close.
I have emery clothed the shaft and cleaned the nylon cog, it's all back together now.
I have run the car for about 100 miles now and have not had restricted performance return
Hopefully it lasts and has saved me the cost of a new valve
Post #680984 22nd Dec 2023 9:39pm
