![]() | Home > Technical (L322) > Front Diff Magically Creating More Fluid |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8567 ![]() ![]() ![]() |
Transfer case is nowhere near the front diff, nearest oil is the engine oil, how's the level...?? Pete
BLRover Member Since: 15 Oct 2023 Location: Tennessee Posts: 17 ![]() ![]() |
engine oil is showing low as well after being topped up after my first check! |
Not what I was hoping to hear. The prior owner had a new engine put in as the original gave up nearly as soon as he bought it. How bad might this be? Brandon
Huge thanks for the information. I’ll do some digging to see what that fix might entail. Feel free to pass along any more wisdom you might have! Brandon
If the driveshaft has worn through the sump tube, how would oil leak into the sealed diff? I think I’m missing how engine oil could get in there. Brandon 2008 4.2L SC L322 Prior Steward of a 2000 Disco 2 and 2006 LR3 |
Any more information you have on this? Not seeing much on this topic elsewhere. Not even able to find the part for the oil pan extension. Thanks again! Brandon 2008 4.2L SC L322 Prior Steward of a 2000 Disco 2 and 2006 LR3 |
Would it be likely that I would see an oil leak near the rear of the diff if the sump tube has been worn through? My only evidence of a leak seems to come from the diff breather hose up by the airbox. Brandon
Would it be likely that I would see an oil leak near the rear of the diff if the sump tube has been worn through? My only evidence of a leak seems to come from the diff breather hose up by the airbox. Brandon 2008 4.2L SC L322 Prior Steward of a 2000 Disco 2 and 2006 LR3 |
Makes sense (even though I don't want to believe it!) I don't hear any sounds upon acceleration and there's no leak other than the breather hose so it's mainly just my inability to get my head around the possibility I could get engine oil in my diff. However, if I've learned nothing else in my prior ownership experiences, it's that one should generally trust the wisdom of the community and with a rover anything is possible. I'll follow your recommendation of dropping the long shaft and see what we see from there. Thanks again. Brandon 2008 4.2L SC L322 Prior Steward of a 2000 Disco 2 and 2006 LR3 |
Upon further inspection, (thanks to my friend with a lift) there is no visible wear or touch point above the drive shaft. Is there an internal seal between the oil pan and the diff that could be allowing the transfer of engine oil into the front diff? I'm assuming I'll have to drop the diff to find out, but I would be keen to know what I'm getting into beforehand. Brandon
