![]() | Home > Technical (L322) > infra-red blocking windows on L322 2007-2009 series |
garyRR Member Since: 13 Mar 2021 Location: Hampshire Posts: 1480 ![]() ![]() |
It may be terminology, however the L322 had solar attenuating glass to the windscreen from 2008 onwards (I believe it was an option prior to this - maybe check for the term in the brochure), claiming to absorb the sun's infrared opposed to allowing it to pass through. I believe it reached the side windows when the double glazing/laminated glass was introduced in 2009/10, as the windows are also stamped. My 2011 definitely has the tinge of colour to the windscreen and side windows.
Jd1566 Member Since: 13 Dec 2023 Location: Queensland Posts: 5 ![]() ![]() |
Thanks GaryRR for that.. clearing up my terminology. The L322 I'm looking at is the equivalent of a UK Vogue SE. Sold in Australia as a Vogue Luxury, so it has a lot of the Supercharger goodies.. but not all. However no mention of what type of glass. I guess I'll just have to sit in it on a hot day and see how bad it is. |
GraemeS Member Since: 06 Mar 2015 Location: Wagga area Posts: 2561 ![]() ![]() ![]() |
You won't need a hot day, just the sun shining to determine whether or not the glass is solar attenuating as there is basically no heat transferred. |
