Home > Maintenance & Mods (L405) > ACE/ARC Front Pipe Connection
NoHandSignals
United States 2016 Range Rover 5.0 SC V8 Aruba
Hi, I am embarking on changing my ACE pipes at home myself, and have got stuck on what I thought would be the easiest connection to do first Smile
Can anyone tell me how the front left connection that goes to a small cooler comes undone? I can feel the connection tucked above the front rail body structure in the front left wheelhouse, and from the new pipe it looks like it is some sort of snap fit, but I cannot figure out how to disconnect the old pipe?
Obviously don’t want to break anything, so any insights appreciated:)
2016 LHD 5.0
Post #678892 28th Nov 2023 3:40am
Phoenix
Post #678895 28th Nov 2023 8:24am
NoHandSignals
Thanks, much appreciated. It will be here from amazon tomorrow and I will get on it at the weekend Smile
...and there was my thinking all I'd need was a 10mm socket! Smile
Post #678960 29th Nov 2023 2:33am
ChrisJC
United Kingdom 2014 Range Rover Vogue SDV8 Aintree Green
I made up this to release the connection. I think that the two bits of copper pipe were for the union in question, and the black thing was for a different connection.
Chris.
 L405 - 4.4SDV8 Vogue
P38 - 4.6V8 HSE
Land Rover series IIA V8
Post #679046 29th Nov 2023 6:54pm
NoHandSignals
Thanks guys, the tool Phoenix posted worked a treat. I can also see how your copper sleeved would work too, Chris. Nice handy work there!
Post #679397 4th Dec 2023 1:46am
NoHandSignals
Next ACE pipe I could do with some advice on how to disconnect is from the other side of the engine bay, I guess it’s the other half of the cooling line for the ACE.
Any idea what tool I need here and/or tips to disconnect? 🙂
Post #679398 4th Dec 2023 1:52am
ChrisJC
That must be what that black tool I made was for... Looks familiar.
Chris. L405 - 4.4SDV8 Vogue
P38 - 4.6V8 HSE
Post #679454 4th Dec 2023 7:27pm
Phoenix
Post #679455 4th Dec 2023 7:33pm
NoHandSignals
Thanks, guys. Much appreciated advice. I will get on it and give it a go at the weekend! Smile
Post #679594 6th Dec 2023 5:19am
NoHandSignals
Got it done. Easy once you know how 😆
Got this Lisle tool from Amazon after failing at fabricating my own. Perfect fit for the job.
Sharing in case of need from other newbies!
Post #680580 17th Dec 2023 9:52pm
ChrisJC
Nice!
I always have the issue that I know what the special tool should look like, but have no idea what it's called. So I make one.
P38 - 4.6V8 HSE
Post #680681 18th Dec 2023 7:06pm
onetwentie
United Kingdom 2013 Range Rover HSE SDV6 Fuji White
Hi all.. I'm trying to source a replacement for my ACE pipes.. they are leaking at the driver's side front (behind the wheel arch.. further down.. I've attached some pictures below.
I think this is the pipe (or set of pipes) that I need:
But I have searched a lot and cannot seem to locate a used one? the new ones seem to be close to £500!
Here is the leak:
NoHandSingals can I ask where you sourced your replacement pipes?
Thanks
Post #704245 11th Nov 2024 6:33pm
They rust from day one and leak in 5-10 years, IMHO a waste of time fitting second hand, most of the cost is in labour....
See this thread for details....
https://www.fullfatrr.com/forum/topic67828.html Pete
Post #704247 11th Nov 2024 6:40pm
onetwentie
Thanks Pete. Just reading through it earlier. I see you got your pipes from Duckworths.
I think I will take your advice and just buy new. I've had some help from Fisha via PM so all being well I should be able to tackle it on a dry day, albeit it will be done with axle stands and a trolley jack!
Thanks all. Thumbs Up
Post #704282 12th Nov 2024 12:27am
